Question about Toshiba Computers & Internet
I have a toshiba laptop and the screen doesn't turn back on after I closed it the last time it was used. How can I fix this?
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    What was you doing the last time you used it? Changing drivers or settings?
    God Bless Greg
  • Toshiba Master
  • 4,806 Answers
Press on/off button, its probably in sleep mode
regards
Posted on Nov 29, 2008
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
How to solve a flickering screen for toshiba satallite m200? as i open my laptop its hang and the screen is flickering...
@crisanne_21
Most of the time, that cause of that flickering screen is a defective LCD flex cable or sometimes called LVDS cable (this is the cable that attaches the LCD panel to the motherboard - it can be caused by a loose connection or simply, it just may have worn out due to opening/closing the lid). The only way to fix that is to replace disassemble the computer and check if there's a loose connection on that LCD cable. If disconnecting / reconnecting the LCD cable doesn't fix the issue, you might need to replace it Disassmebly guides can be found here.
Good Luck
Sep 05, 2011 | Toshiba Computers & Internet
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
Laptop turns on and the monitor only turns on for a second.
you need to open the laptop and check the screen, it is possible that the flex or screen inverter that connects the screen to the laptop motherboard has shifted or has loosed contact or is not firm to its right position.
All you need to do is to open the laptop, if the flex is removed, fix it back to its right position and that's all.
Also, do a general troubleshooting on the screen and the problem should be solved.
Good luck.
May 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba satellite l355d-s7825 that, when booting up (before welcome screen) seems to go into some type of sleep or hibernate mode and the monitor flickers and goes out. If I open and close the...
hi
  1. Turn your computer on.
  2. Start pressing F8 on your keyboard about every second as soon as you turn the computer on until you see the screen shown below.03b7e06.png
1:Select "last known good configuration " using the arrow keys.
your laptop will be restored to the time it was working properly
still your problem is not solved then
2:instead of selecting " last known good configuration " now you select safe mode from here you safely turn Off the laptop.
3:if the above solution did not solve your problem do System restore
please rate me
Jan 02, 2010 | Toshiba VGA Board Graphic Card
I have a Toshiba Satellite A305D-S6848. Last
Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons (or those appropiate to your model) to send the video signal out to the external monitor. If you do not get any image on the external monitor it means that most probably the mainboard is damaged (video card or even more). Expensive to fix or replace. Have it checked by a professional.
Oct 06, 2009 | Toshiba Satellite A305D-S6848 Notebook
Toshiba laptop screen
Can you see the toshiba loading screen when you first turn on the system? If yes, then load in safe mode and uninstall the driver and reload the video driver from toshiba's web site.
If you cant see video at all. (try) reseating the video cable to the motherboard, some laptops have a nasty tendency of having that cable come loose after beign opened and closed for awhile.
Jan 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
My laptop toshiba screen is not fuctioning
Bring it back to Best Buy ASAP. Best Buy should replace it.
Dec 02, 2008 | Computers & Internet
My toshiba
Did you try Last Known Good Configuration?
http://support.microsoft.com/kb/307852
try this if ur notebook shows a little sign of life....
or else
1. unplug the laptop
2.take out the battery
3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit)
4.put battery back in
5.plug in laptop
6.try to turn it on
All the best
Have a nice day!
tc
Jun 11, 2008 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
