Question about Frigidaire GLTF1670A Front Load Washer
Frontloader washes and rinses on cold all cycles but whites
Ever since we bought the machine new (4 yrs ago) the cold cycle for all types begins to fill as normal then the rinse light comes on and the machine begins to drain the water it's filling with. So, I babysit the machine and switch to warm then it stops draining. I've adjusted the water coming thinking the cold water is filling so fast that the it begins to drain. The drain hose is 40" from the floor. The water spout is a bit lower than 40". Any ideas before I call it in?
  • Anonymous Mar 25, 2014
    no resistance @ lid switch and timer,but low 0.8ohm@ water inlet valve solenoids except 1 on top of valve has 130ohms? bad valve?
    Champion:
  • 249 Answers
Drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Posted on Dec 15, 2007
Water will come in at beginning of cycle on a Hot/Cold wash but not in rinse cycle?
because the rinse uses cold water and u may have a cold water issue with the water inlet valve, the water inlet valve cold coil may have gone bad. test it with a meter and voltage
May 11, 2015 | Whirlpool GHW9400 Duet Washer
After 2 yrs. the cold/cold selection doesn't work at all but the other selections give me hot h2o only. Also, rinse cycles just stopped working!
Your water inlet valve has 2 electric coils on it. One for hot --one for cold. The cold is probably bad. Most newer machines use COLD rinse only so if no cold fill it just stops in the rinse cycle. Replace the inlet valve which is the part on the machine back the hoses hook to.
Mar 23, 2015 | Admiral AW22 Top Load Washer
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Frigidaire GLTF1670A Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
