Question about Pioneer Televison & Video
Tv will not start up normally
I have a plasma screen tv, the model number is as follows pdp06ru. The tv never gave me any problems until a couple of days ago. When you put the tv on you get an error message (starting up) but the tv will not go on you have to get up and unplug it for a minute or two and then hit the power button for it to go on.
Please help me determine the problem here.
    Sergeant:
  • 195 Answers
Bad capacitors on the power board. Check to see if they are bulging or swollen. If they are, then most likely that is your problem.
Posted on Sep 07, 2017
SOURCE: AKAI LCT2785TA TV does not turn on
look closely at the electrolytic capacitors in the power supply. If you see any with the tops bulging out, replace them. Especially the 1000mfd caps labeled EC9, EC10, EC18, EC19, EC20
Posted on Sep 22, 2008
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
  • 55 Answers
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
Posted on May 09, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
SOURCE: TLA-04011c 40in. LCD TV: Red light is on. TV
I have the same TV and I just replaced the Capacitors. It came with 2 10000UF 10V caps and I put in 2 1000UF 35Volt caps from radio shack. Its like brand new. There is even a video on how to change them on You Tube.
Posted on Nov 16, 2009
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
Feb 01, 2016 | Samsung HP-S5053 50 In. Plasma HDTV
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
I have philips model #42pf13704df7 when I turn it on it stays on couple second then it turns it self off, I have to turned on again and again until it finally stays on and sometimes it goes off again
I tried to find out if this is an LCD screen type or Plasma or DLP, but I couldn't find a straight answer. The only info I could find was several links all leading to your questions about the problem, which means you must have one or more of the models numbers wrong. Anyway, you have the symptoms of a DLP bulb going bad. _IF_ it is a DLP, then for sure that's your problem. The bulb is quitting. If it's a Plasma, then it's the beginning of the end for it; (the plasma display is getting ready to quit for good). If it is an LCD, then I've never heard of one doing that, so I don't have an answer; other than the power supply kicking out, but they usually quit for good pretty fast after the first couple of times. Sounds like a bad bulb in a DLP TV or a bad plasma display in a plasma TV.
Dec 31, 2014 | Philips Televison & Video
It coming on and after a couple of seconds cut off
Without a brand AND model number or a better description of the problem, any suggestions would be nothing more than a guess.
Unless you are prepared to repair the TV yourself, professionally performed repair, even simplest ones, will probably exceed the cost of a new LCD replacement set.
Due to X-ray and other safety concerns (equipment and/or people), CRT TVs constantly check the voltages and signals required to make a CRT work. A few seconds grace is allowed during start up but after that, any excessive high voltage (real or imagined) or loss of beam deflection circuits will cause the TV to turn off.
Please do the following:
1. Move the TV to a quiet and preferable totally dark room.
Wait until night if necessary.
2. Stand within an inch or closer to the TV screen.
3. Turn on the TV and look and listen for the following:
a. Whoosh sound and/or head hair attracted toward TV screen
Yes. High voltage activated and charged CRT screen.
No. High voltage failed to activate.
b. Hissing or normal sounds from the speaker(s) while set is on.
Low voltage circuits probably okay. Defective low voltage regulator can cause high voltage to exceed limits.
c. Entire screen briefly lit up or single bright spot at center of TV screen
High voltage worked for a moment then the TV shut off due to over voltage or current problems.
d. Brief bright line from top to bottom or single bright dot on TV screen
horizontal deflection circuits bad
vertical deflection circuits ok
TV shut off due to bad deflection/sweep circuit
e. Brief bright line from left to right on TV screen
It would be helpful for you to perform the above "up close and personal turn the TV on test" and report what happened.
Nov 26, 2014 | Televison & Video
My 2006 manufactured Viore flat screen plasma tv suddenly went blank. Still have sound. Please help!
Read the following:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
Different TV, but most likely same problem and, in fact, quite possibly literally the same boards, so maybe practically the same TV.
Can't be sure since you haven't posted the model of your Viore.
If you have specific questions, please always include the model number in the question...the model is on a sticker at the back of the TV, right after or below the words "MODEL:" :-)
Nov 09, 2011 | Toymax Viore 42 in. Plasma TV
I was given a fujitsu plasma screen. Where can i find the model number so i can get a owners manual?
You can usually find the model number on the rating plate on the back of the TV. Model numbers for 42" Plasmavision screens appear to begin with P42 followed by some more letters and numbers.
HTH
Oct 12, 2010 | Fujitsu Plasmavision 42" TV
Shaking lower half of the screen worsens with time on
Hi, Suggest to take to a local Tv Repair Shop. Thanks.
Sep 22, 2009 | LG 42PC3D 42 in. Plasma Television
Sony Trintron Model # KV-27S22 Flashing screen
Hello
I got it fixed today at the TV repair shop down the street.
Thanks
Nov 11, 2008 | Sony HT-DDW840 System
Zenith plasma
dont get mad like i did, report this problem to zenith, they seem to be aware of the problem with this particular model.
i gave them the model number and they requested the purchase date, then extended the warranty and gave a number for a local repair shop which came for my set a couple days ago.
so far so good. it may be a while until i know whether the repairs will work, however hats off to zenith, so far, which seems to be providing appropriate customer service and standing by their expensive products.
Jan 14, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
35 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
