Question about GE Profile Harmony DPGT750GC Gas Dryer
G.e. Profile gas dryer, wont turn on but has power
When I go to twist the start switch nothing happens, I call a appliance repair place and they said it could be a fuse. Were are these fuses located at, and how hard is it to repair this?
Bryan
  • 1,543 Answers
Some GE dryers use a non-resettable thermal fuse. It is a dime sized object with two wires attached on the top of the element housing. (Unplug dryer, take screws out or push in clips holding dryer top down at the front of the dryer top, swing top back, see thermal fuse near very back) Newer dryers use an automatic resetting thermal fuse. The replacement part for either will be the same auto resetting one. Your problem could be several other spots, however. Check for 240 volts at dryer. (not just 120) When you swing that top up, make sure the belt is there going around the drum. (if belt broke, it switches off power on most dryers) Could be a door switch, internal motor switch, timer contacts, bad start switch, burnt off / broken wire, maybe just a stripped over start knob.
If you find that the thermal fuse was the problem, you still should clean out the vent and eliminate all or as much flex duct as possible to prevent the thermal fuse from tripping again.
Posted on Nov 29, 2008
Whirlpool Duet Gas Dryer won't start
Appliance Repair Forums Possibly the thermal fuse.
There are alternative routes such as following toubleshooting guides or putting the dryer into diagnotic mode in order to narrow down the problem but it will may boil down to being the thermal fuse.
Sep 03, 2017 | Power Computers & Internet
GE profile gas dryer wont turn on. There is power to the unit.
The service manual is here:
http://www.affordableappliance.com/Download%20Folder/GE_Harmony_Dryer.pdf
Things to check
1. Belt switch and belt on page 26
2. Door Switch on page 25
3. The inlet manual; (reset) safety switch on page 30
4. The outlet thermistor on page 31
These 4 switches and thermistors control power to the control panel. Find out which one has failed.
Kelly
Kelly
Sep 26, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Maytag Dryers
Power is on but nothing is happening when i push start. the dial wont let me change the time/dry setting. everything is lit up just nothing happening.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Samsung DV218AEW Electric Dryer
When I try to turn my dryer on, it just clicks - nothing starts up. The light turns on for a second, while I'm engaging the "start" dial, so i know there's power, but after that, nothing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 10, 2010 | GE Profile DPSB613G Gas Dryer
Turn the no switch nothing just a little hum what
check the drive belt ... if broken, thank your luckey stars it was not the motor ... could be the motor start circuit.
Jan 05, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer will not start
CHECK TWIST TO START SWITCH OR DOOR SWITCH
Apr 29, 2009 | Dryers
Oven wont turn on
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Won't turn on
First check voltage and breaker,(this is a big one)
next, if you have power to the appliance (120 gas dryer or 240 electric) then the door switch is probaly broken.
lastly, perhaps a thermal fuse located on blower vent. goodluck
Dec 17, 2007 | Amana DLE330RAW Electric Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
872 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
