Question about Kitchen Appliances - Others
Water kettle does not boil water
My electrical water kettle stoped boiling water. It worms it up but than it turns off, on and on for 2 -3 times and stops.
type TEA JOY ROYAL
  • teahead Dec 06, 2008
    water doesn't boil
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Posted on Dec 25, 2010
  • Tanya Fernandes Oct 06, 2011
    Tried this method and wow my kettle started boiling water back again.... Thx so so much for this solution we were about to discard the kettle . I had a descaling solution though but Vinegar is also a good to descale......
Check to make sure the water is at least at the minimum level.
Posted on Dec 07, 2008
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
How do i get rid of a taste when making a brew
Water and white vinegar will descale your kettle which may be causing the taste. Follow these instructions:
http://www.topcleaningsecrets.com/house/kitchen/how-to-clean-an-electric-kettle.html
Jan 19, 2015 | Kitchen Appliances - Others
I cannot take off the lid of the Pro chef and manual is unclear. How do I unlatch it?
Manual Pro Chef PU 100
I have received the hot water boiler, but it does not stop boiling the water. Instead of going to "Keep Warm", the machine continues to boil the water indefinitely. We left the boiler on and came back after 2 hours, and it didn't stop heating the water. Therefore, I refilled the boiled, turned off the machine, unplugged it, plugged it back in, and then turned it back on. The water continues to boil without going to "Keep Warm". I require a solution to the issue or a replacement as soon as possible.
Apr 25, 2014 | Le Chef Electric Shabbos Hot Water...
The switch does not automatically turn off when the water boils. If left alone all the water will boil out.
The switch has to turn off when the water boils as the heat generated must cut off the switch. If this wont work the bimetal is not working and the switch is not responding.
You will need to replace the switch. Please contact the dealership for the spare.
check this link for spare:
http://www.espares.co.uk/brands/kettles/p/1102
Sep 21, 2011 | Oster (3211) Electric Kettle
I have a new Bellini electric kettle. When I turn the kettle on, it starts to boil for a few seconds and then turns itself off. It will boil if I hold the "button" down for a while until it...
Unfortunately the problem is in the switch mechanism, and will need to be replaced to correct the problem. My sense is it would be cheaper to replace the kettle than trying to find somebody to repair it.
Mar 13, 2011 | Kitchen Appliances - Others
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Jun 28, 2010 | Russell Hobbs 14339 Cordless Electric...
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Electric cordless kettle
This can happen on new mettalic kettles, the aftertaste may dissapear after a while with use as it did with mine.
Oct 25, 2008 | Faberware FCP512S Cordless Electric Kettle
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Kitchen Appliances - Others Logo
1,435 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
