Question about HP PSC 1315 All-In-One InkJet Printer
Scanning on HP PSC1315
Between using vista and the scanner I am lost. Can you put me on the right trace?
I have a 1315 hp printer all in one,every thing is fine only unable to use scanner. i have to download the the programme. i have vista programme
Posted on Dec 01, 2008
Hi
can not use my scanner can not find the program like on xp windows now I have vista
Thanks Roger
Posted on Nov 30, 2008
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
I need to upload scanner onto Vista . I bought the Vista. The HP psc1315 was attached to my old HP pc. I do not have the software to connect the psc1315 scanner to the Vsta.
I'll guide you to how to get your needed software from HP Support.
First, I would like to ask that you have the printer disconnected from your computer. (USB cable)
Also have the printer turned off, and unplugged from power. (Surge protector)
This is HP Support, and the main page for the HP PSC 1315 All-In-One InkJet Printer,
http://h10025.www1.hp.com/ewfrf/wc/product?product=374568&lc=en&cc=us&dlc=en&submit.y=9&submit.x=7&lang=en&cc=us
1.On this page you will see the heading - Software and Driver Downloads. Click on this heading.
2.On the following page you are asked to choose your Operating System. Vista, or Vista 64 bit.
If you know for sure that your Vista version is 64 bit, then choose Vista 64 bit.
However it doesn't matter.
Both versions of Vista, (Vista 32 bit and Vista 64 bit) use the same version of HP Full Feature Software.
[ Date: 09-2009 Version: 080.001.237.001 ]
(This is due to the fact, that some programs are designed to operate both on a 32 bit operating system, and a 64 bit operating system. It's up to the program manufacturer, and in this case, HP has made it so that their Full Feature Software complies with the above. Operates on Vista 32bit, and Vista 64bit)
3.After you have chosen which operating system by clicking on it, you are taken to the appropriate Compatible Software and Drivers page.
4.On this page you will see the heading - Driver, in blue.
Down below it you will see - HP Full Feature Software and Drivers
Left-click on it.
5.On the next page you will see a blue rectangular square with Download Only >> in it, in the upper left corner. Click on it.
6.A small rectangular window will pop-up to the right.
In the window click on - Save File
7.You should now see a download status bar. Let the file download all the way.
8.If you do not have your downloads set to go to your Documents folder, this file will go to your desktop screen.
Double-click on the file name. Follow the simple instructions of the Installation Wizard.
(When it shows you where the file is going to be put, do not make any changes. It will put the file in the appropriate place it's supposed to go)
When the Installation Wizard is finished, you may be asked to restart your computer. If you are not asked, do so at this time.
After Vista has reloaded and is running, plug the USB cable of your PSC 1315 printer into your computer.
Now plug the printer into power. Wait 30 seconds. Then turn the printer on.
Should you have problems with this, please come back and post.
Sep 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Jan 13, 2009 | HP PSC 1210v All-In-One InkJet Printer
HP Printer - Scanning Documents
i had the same problem with vista home premium. vista does not support one touch scanning (pressing the scan button on the printer). to use scanner with vista home os use the paint application and start scanning with the file section. step by step:
start (windows) icon lower left tool bar
programs
accessories
paint
file
from scanner or camera
the hp should start working - note: i sent a short cut to the desk top for the paint program for future use
Dec 06, 2008 | HP Photosmart C3150 Printer
Hi i am lost my printer cd 1315 all-in-one
Go to this page:
HP PSC1315 Downloads
Select your operating system. If you have Vista, XP, or Win2000 you can order a new CD, or you can download the software directly from HP.
Nov 25, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanjet 3970 and Vista
since This driver enables scanning with the Windows Photo Gallery on Windows Vista or the Scanner and Camera Wizard on Windows XP. some features may no longer be available when using this basic driver.feature driver for Windows Vista or Windows XP Professional x64 . You can upgrade to an HP product or driver that is fully compatible with Windows Vista or Windows XP Professional x64 that will support the additional features
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=298547&prodNameId=298549&
swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=sj-47402-1
Aug 22, 2008 | HP ScanJet 3970 Flatbed Scanner
Hp psc 1315
yes u can use Printer in win vista operating system
for that u have to diwnload drivers of psc1315 for vista support if u want to download please use below link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=374568&lc=en&cc=us&dlc=en&lang=en&cc=us
using this link please select u r correct Operating system
then download what u want , in this link u find all drivers & software for psc1315
If this Link useful for u please Rate me ......
It is Helpful for my Rating avg.
Jun 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
