Question about RCA P52921 52" Rear Projection Television
56" RCA projection TV
Can someone tell me what is the horizontal drive trasformer is? and what part number and location on board it is on a CTC195M chassis of an RCA rear projection TV model P52921. Thank you!
  • Haitham Moaty Jan 17, 2007
    Thanks a lot! do you know what number would it be on the board both the HOT and the horizontal drive transformer or either?
    It would be wonderful if I can get the part number too so I can purchase.
    Scholar:
  • 119 Answers
Part # from rca is 215541
Posted on Jan 17, 2007
    Novelist:
    Champion:
  • 236 Answers
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
RCA Projection television CTC195M I need the transistor number
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 26, 2016 | RCA Televison & Video
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
I need to locate a replacement deflection board for my RCA HD TV part #267147R
I will need your old board as a trade in core, then a new board is $325.76 plus Shipping & Handling E mail:Cheese City T.V. Service at dmftrucker@yahoo.com Thank You
Nov 18, 2009 | RCA HD56W58 56" HDTV
RCA-Churping Noise
it needs horizontal supply repaired and all will be well....
May 28, 2008 | RCA P56923BL 56" Rear Projection...
Proscan s56700
call tech ...suggest checking horizontal drive.
Nov 12, 2007 | Proscan PS56700 56" Rear Projection...
RCA ctc 195 series
this tv most likely has a shorted horizontal transistor and transformer. Now that you have a heads up on the problem it's best to contact your local tv rep. John
Sep 13, 2007 | RCA P56950 56" Rear Projection Television
56 rca hdtv
ANy way you look at it you'll have to take it to the shop. A tech can use the secret service menu to adjust the vertical & horizontal size. Or you may have whopped up B+ issue, that could be hard to find so replacing the deflection board woul;d solve that, hope this helps.
Aug 02, 2007 | RCA HD56W66 56" HDTV
56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Jan 16, 2007 | RCA P52921 52" Rear Projection Television
RCA TV PROBLEM
check the horizontal o/p transistor I suspect it's shorted, find location Q14401, on the board it's marked as q401. it's located near the flyback on a heatsink. if it's bad the rca part number is 242224. good luck
Dec 13, 2006 | RCA F27442 27" TV
56 projection t.v. color problems
If you mean they are separated like a 3-D effect, then you have the typical bad convergence IC problem. There are two IC's mounted on a large metal heatsink, they will have STK392-###, the ### being differant models of TV sets. these are soldered into place and are no usually replaced by the user, unless you have solid state repair experience, knowe how to solder, have a schematic on the set, and know the High voltage safty factors of projection TV serviceing. If you have no experience, please play it safe, and get someone who is trained to service TV sets. Good Luck Please do not forget to rate this thread.
Dec 08, 2006 | RCA P52926 52" Rear Projection Television
RCA P52921 52" Rear Projection Television Logo
179 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
