Question about Insignia IS-LCDTV32 32 in. Television
Insignia NS-32LCD Will not turn on..but red and blue light show!
Ok so I've been reading all of these problems with this crappie TV and I have it cracked open. The capacitors are not swollen or busted. Where do I go from there? TV makes a quick pop (not long but just a pop) when I press power button..but nothing else except that the light turns blue. Does that mean that the power supply is ok?(Especially since the caps are'nt swollen or leaking). What now.....
  • jcarlos_66 Feb 10, 2009
    when i turn on my tv a red light comes on but nothing else what can i do
techman
  • 3130 Answers
SOURCE: Insignia NS-32LCD...Manufactured 2-07
This set should still be under a manufacturers warranty. This set has a board that is very hard to get. Do not let them tell you to wait, or you will wait and not get the set repaired. You need to call and have them repair or have them replace the set before the warranty runs out. If you do you will have a hunk of junk.. Good Luck
Posted on Sep 12, 2007
  • 2336 Answers
SOURCE: Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
Posted on Aug 21, 2008
SOURCE: How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
Posted on Jan 28, 2009
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Posted on May 18, 2009
welcomejee
  • 10594 Answers
SOURCE: insignia ns-32lcd. picture scrolling and no sound
Hi, I was waiting your response in chat session but didn't get any.
Posted on Jun 11, 2009
Insignia NS-32lcd wont turn on?
check whether all the wires are connected at proper place and firmly.loose connection also gives this problem after new board is attached.
thanks.
Sep 21, 2008 | Televison & Video
I have an insignia NS-32LCD and it will not turn on
Capacitors are probably bulged in the power supply. Need replaced, not expensive.
Oct 10, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Insignia model ns-32lcd will not power on.
If you wish to get some details; visit the site linked here. Pull up older posts.
May 17, 2017 | Insignia IS-LCDTV32 32 in. Television
Jan 27, 2009 | Insignia IS-LCDTV32 32 in. Television
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Aug 25, 2008 | Televison & Video
Aug 21, 2008 | Insignia IS-LCDTV32 32 in. Television
did you try calling the (877) 467-4289 Insignia help line?  I think they're open 24/7.  They just solved another Insignia problem for me.
May 13, 2008 | Insignia LCDTV26 26 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
266 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
