It's always turned on, the little green light is always on, except for when I turn the computer off, and I've tried plugging the camera out and in again but it won;t work. What do I do? Please help!
SOURCE: my web cam is not working on line
Normal 0
Web Camera’s have to be setup on the program they areto be used with. Just installing thecamera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see andtalk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger setit up as follows:
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: genius messenger 310 webcam
san po ba makakakuha ng installer ng genius nawala po kc ung installer ko eh pls po .
SOURCE: my computer restarts when i turn on genius webcam islim 310
It's mybe a temperature's problem like all the "restart" problems. Buy a cooler or something or take your computer to an expert.
SOURCE: i have a genius islim 310 webcam and it cant work
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
