Question about Adcom GTP-860II
Component Video Inputs/Outputs Not Behaving as advertised
I decided to switch my video cabling from S-Video to Component. Went out and bought 3 sets of cabling (Monster, if it matters). The Adcom has component video inputs for Video 1 and Video 2, and a Component Video Out. I wired it like this:
Video 1 - S-Video Input from Dish Receiver (no Component Video jacks there)
Video 2 - Audio into normal RCA jacks, Component Video into appropriate jacks
Component Video Out - Cabled to back of TV
The results? Not pretty. By process of elimination, determined this is what is happening. Once the Video Out cables are in, the unit ignores any composite or s-video input. Which means no picture on video one from Dish (audio is there, though), but video on one is from... video 2 - the DVD player. On Video 2, there is both sound AND picture from the DVD player, but it is very dark. Checked DVD settings, and found nothing I could change to alter this.
I'm thinking the switching for the component video jacks is fried - have been through all the menus, and found no settings I could change. I don't really want to yank the unit from the rack, since it is literally the heart of the system. I have an old Sony TA-E9000ES (completely lacking in component video jacks) I may have to bring off the bend whilst the Adcom goes to the doctor.
Any suggestions/idea's (not holding my breath for a quick fix here) would be greatly appreciated.
Cheers
Nick
    Scholar:
  • 31 Answers
I have had this problem in the Field with a Client. I had fixed it by going into the ADCOM menu and Resetting ALL of the Inputs and output for the Devices. You have to select everything you need, then exit out of the Menu, SHUT OFF the ADCOM, WAIT about 10 secs, then turn it back on. Or Else it Does Not SAVE Properly! Weird. If you can not see the Menu on the TV Screen then try to hook up a Composite (Yellow) cable from the ADCOM to the TV and select the TV input to make the Changes. I really hope this helps out it sounds like an Evasive problem which is hard not being in front of the Equipment!
Posted on May 05, 2009
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: http://www.amazon.com/Panlong-Switcher-Composite-Selector-Consoles/dp/B00KXVBB3Q/ref=sr_1_24?s=audio-video-accessories&ie=UTF8&qid=1440632814&sr=1-24 .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I need help putting my surround sound to my tv .dvd and x box
2 ways to do this
if your tv has multiple inputs and an audio output its easy if not there is a way but its more complicated
if your dvd and xbox have HDMI (link to inexpensive hdmi cables) outputs pick up some cables on ebay and use that to go directly to the TV then use the audio output of the Tv and run it to any input on your receiver EXCEPT PHONO. I use video 1 since its easy to remember.
all you do is set your receiver to video 1 and then set your tv to the input you want to watch ie: video 1 for xbox, video 2 for the dvd
this will also work if you use component inputs on your tv (the red, green blue ones)
Now the harder way to do it.
Your receiver has high def (red, blue, green) component inputs
plug your dvd, xbox and cable box if you have one into the 3 video inputs on your receiver and teh TV audio can be plugged into the CD or aux input.
here is the issue.
running both the audio and VIDEO signal through the receiver may degrade your video quality based on the type of video processor that your receiver has.
secondly lets say your dvd doesn't have component outputs and you have to run s-video cable instead then you have to run multiple monitor outputs to your tv as the receiver wil not "upconvert or downconvert" the signal from one format to the other.
Newer higher end receivers will do the conversion but usually not until you get into the $500 and up price point.
when i do installs I try to ,ake it so that people have to push the fewest amount of buttons. Most people know how to switch the input on the TV but then get confused if they have to also start switching inputs on secondary devices such as receivers
hope that helps
Feb 19, 2010 | Yamaha RX-V461 AV Receiver
How do I know which converter box to buy?
here are the specs for the Magnavox TB100MW9
Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
Jan 04, 2009 | Televison & Video
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
HD Outputs
you mean inputs.
Press the TV/VIDEO button on the remote till the TV goes to the input you want.
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
DVD cables
You have to plug your DVD cables into the "input" connectors on your tv. Input audio and input video. Also there is either a switch on the back of your tv or in your menu where you have to choose "component video". Or it might be labled Video 1, Video 2, Video 3, etc. You might have both a switch on your TV and a choice in your menu. If so, both have to be set to "component Video. Sometimes on the back of your set, the switch is not labeled. It just has "arrowed" lines coming from the different switch positions and leading to the "outputs and inputs" on the back of the set. Set the switch so that the lines lead to the red, blue and green INPUTS on the back of your set. Your problem is not serious. It is just a matter of "telling" your TV that you are using "component video". Component video is when you are using the red, blue, and green inputs. It is also possible that your DVD has another output besides "component out" and also has a switch. Make sure this switch on the back of your DVD is in the "component OUT" position. Your DVD might also have a connector on the back that looks like connectors on the back of VCR's and most TVs. This is an "F" connector and the cable has to be screwed on. It's just like a cable tv cable. Screw a cable into the "out to tv" on the back of your DVD and screw the other end of the cable into the "RF" INPUT (or cable input) connector on the back of your tv. Be sure to look ALL through your TV menu and DVD menu. The DVD sets to "component OUT" and the TV sets to "component IN". Hope this helps.
Keever
Mar 04, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
All inputs fail to accept video sginal
sounds like the video switching ic is faulty,contact your local shop for an estimate to repair the fault.
Sep 06, 2007 | Mitsubishi WS-55809 55" Rear Projection...
139 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
