Display black cant see well or at all.
I believe that the monitor is burn out but not sure the screen is black I can see something but very poorly I plug a dell monitor in and I can see fine is my laptop display burned out??
  • 31 Answers
I'm afraid that's right, your laptop display is malfunctioning
Posted on Nov 29, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
My motherboard and monitor have hdmi ports and a hdmi cable connecting them. When I sellect hdmi mode on the monitor, the screen goes black and then a message comes back saying no hdmi signal. Is there...
Hello, I'm not sure about the system or monitor that you're using, but usually for Windows systems, you have to change the display within the system before the screen will actually show on the monitor through something other than the standard display port. If you reply with your OS, then I might be of more help, but assuming you have Windows 7, you must plug the hdmi cord in, right-click on the desktop, and select Screen Resolution. Then select the option (likely "HDMI") under Display that you are currently not using. At this point, your current screen will most likely go black. Switch you monitor to hdmi mode, and then you should be able to use your monitor via HDMI. If you have any questions, please feel free to contact me, or simply comment.
Feb 17, 2011 | Computers & Internet
Only see a black screen all touch functions work just cant see whats displaying
mcdevito75 here, Monitor can be burned out, the picture portion of it. Exchage with a know good one or bring the monitor to any computer reair place, Staples, best buy and they will test it. Also double check all functions specially bright / darker on the monitor.
Jun 25, 2010 | Pioneer AVH-P4000DVD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
Dec 18, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Screen Display gone black
your flourescent back bulb is prolly burned out, or something is wrong with your video card. try another monitor to rule out your computer first.
Sep 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Computer turns on, but there is no display on monitor.
The builtin video card is probably bad. Yes, you can get a PCI video card.
Dec 28, 2007 | Dell Dimension 2300 PC Desktop
Screen blacks out.
I had a similar problem with a television. Basically when the element gets to hot it shuts itself down. I believe your monitor is overheating and I dont think there is much you can do besides have some of the guts replaced or pitch it....sorry.
Dec 26, 2007 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
