Question about Pioneer CDJ-800 Turntable
Pitch control adjustment for Pioneer CDJs??
I am now starting to fix CDJ players along with Technics 1200 series turntables. I got the 1200's locked down, but i need to know how to adjust the pitch control on CDJs.Hopefully a technician will read this: i cannot mess up by experimenting with a costumers player. My guarantee: If i broke it, they get my personal 1210s or CDJ MK2s. A mistake or "oops" is no option for me -
  • 515 Answers
Your best option is to get a hold of the service manual for this model. Which is available HERE. It tells you how to align, calibrate, disassemble, and clean the unit. As well as assorted schematics and diagrams you'll need in order to troubleshoot issues with the unit.
Now, just because you've master the 1200s, doesn't mean that this beast is just as easy. It's not. This is COMPLETELY different than an analog turntable like the 1200s. You have to be cautious with ESD, the Laser, and an assortment of other fragile components on this unit.
So, I say, experiment on your own gear, this way you won't mess up a customer's unit. Or buy yourself a used, damaged unit, and work on re-building that one. It's the only way your going to learn.
Hope this helps some.
- OPTiC
DJ PRO LAB
DJ PRO AUDIO
www.1200s.com
Posted on Nov 29, 2008
Technic 1200mk2 pitch problems
Check for bad solderings on Q201 and surrounding areas.
Resolder IC101 and IC201. If that doesn't help, Q2 and Q3, both 2SD637R, could be broken. If that doesn't fix it replace the electrolytic capacitors. Cheers john. Styluscity
Mar 03, 2012 | Technics SL-1200MK2 Turntable
When using my pitch controll the spped does not
the pitch control slide potentiometer needs to be replaced. This is a common failure on the sl-1200 series.
Apr 22, 2010 | Technics SL-1210M5G Turntable
I have a problem with one cdj 200.some gear in the cd player have problem and i can't put out the disc,have you see the same problem again?
There should be a pin on the bottom of the cdj, this is the push pin that will manually release the cd inside. BE CAREFUL!. This will work much like the pinholes in cd trays on computers. Just push it in to release the jammed cd. This may not work, and is only a suggestion. If this does not work, I'd attempt to contact Pioneer directly for a service request. Hope this helps!
Jan 07, 2010 | Pioneer CDJ-200 CD Player
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jan 18, 2009 | Technics SL-1210 Turntable
New pitch Control for pioneer cdj 500 mk 2
Enter your make and model in a search engine like google.
Put "parts" along with your search
Nov 13, 2008 | Pioneer CDJ-500II CD Player
Cdj 700
hi
error E-9101 is notifying that there is dust in the system
get the drives professionally cleaned and reset the units
D
Nov 20, 2007 | Pioneer CDJ-700S Turntable
Pioneer CDJ-800 Turntable Logo
216 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
