Question about Panasonic Radio Communications
Panasonic KX-TCA92 headset wire problem
There is a problem with the cord right at the place where it enters the jack that plugs into the phone. If you move the cord a certain way it will work. It could be a broken wire that makes contact depending on how you move the cord. The headset is only about 5 months old and is otherwise in excellent shape. The question is whether or not the plug can be repaired or replaced? This is the second one of these headsets with a wire problem in the last year. Maybe I should change brands??? Thank you.
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
  • 32 Answers
SOURCE: Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Posted on Apr 28, 2009
  • 8 Answers
SOURCE: Cannot hear Skye ringing thru headset otherwise
try to re install again the skype software on your unit.
Posted on Jun 26, 2009
neutronrace
  • 66 Answers
SOURCE: Headphone jack of my laptop does not work
You have to set the software in order to connect the wright way. with a USB device it will never work.
go to the properties of your audiocard and theire select what you want
Posted on Feb 13, 2010
  • 608 Answers
SOURCE: i just purchased this headset plugged it into the
Do you have sound otherwise? The sound to your headset comes from your sound card. You need to ensure the soundcard is properly installed. If it's ok, check there are no checks in the boxes on your audio controller. Right click on the little speaker icon in the system tray and select "Adjust audio properties", Select the "Audio" tab and choose "Sound playback". Clear any checks from the appropriate boxes and set the volume level to suit. Should now work.
Posted on Apr 18, 2010
Hello i have no speaker phone , when i disconnect the headset i have normal spk phone what to do
If your terms are correct, that's proper operation. Plugging a headset into the headset jack disables the speaker.
Carl
Aug 10, 2011 | Panasonic KX-T7730 Corded Phone
I HAVE A KX-T7633 AND IM TRYING TOGET MY PLANTRONICS CS55 TO WORK WITHOUT UN-HOOKING THE HAND SET
You can use the cord part number 78333-01. (I have included the link.) This will replace the cord that is plugged in between your CS55 charging base and the handset jack on your phone. It will plug into the base of the CS55 and the round headset jack on your phone. You will not have remote answer. Push the headset button on your phone and then press the headset button on the CS55 headset.
Good luck from Headsets Direct!
May 31, 2011 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic kx-t7433 phone does not power up
The phone uses the outside pairs of a 4-conductor base cord to make the digital phone work. Check to see that you are using at least a 4 conductor base cord. Try moving it to another jack that works. If it powers up there, you probably have a mis-wired jack. You can also test it by plugging it into the cabinet directly if you have a TD-816.
Carl
Oct 23, 2009 | Panasonic KX-T7453 Corded Phone
How to connect to headset and to use it
First make sure that your headset is compatible with the Panasonic phone, look at the phone left view, there is a plug hole for headset locate at bottom part. After plug in then return to phone to enable the headset mode. To do this:
1) Press PROG.
2) Press program no. 61 (headset mode) and then press ENTER or STORE.
3) Press selection no. 0=OFF, 1=ON headset mode and then press ENTER or STORE again.
4) Press EXIT or PROG.
YBC (/\)
Jul 16, 2009 | Panasonic KX-T7633 Corded Phone
Headset set up on a KX-T7633
First make sure that your headset is really compatible with the Panasonic phone. After plug in the headset to phone then u need to enable the headset mode. To do this:
1) Press PROG.
YBC (/\)
Jun 23, 2009 | Panasonic KX-T7633 Corded Phone
For use with a headset
LOOK AT THE FRONT LEFT SIDE OF PHONE. THERE YOU WOULD SEE A JACK THAT FITS HEADSET. I DONT KNOW IF THATS THE SIZE YOU REQUIRE. BUT IT SHOULD WORK!!
Mar 24, 2009 | Panasonic KX-T7630 Corded Phone
Need to set the time on a Panasonic KX-T7633
From the phone plugged into jack 1, usually 101, press PROG **1234 000 enter. Your date and time is changed using the arrow and NEXT keys and ENTER sets it after you're done.
Carl
Nov 18, 2008 | Panasonic KX-T7633 Corded Phone
Registering a new cordless handset
It doesn't exactly "register" but you turn it on via phone programming.
Just plug it into the headset jack, then select a button to program and press PROG (the button) and dial 67 enter.
When you press the button, the light will turn on and the display will say HEADSET ON. Pressing it again will turn it off.
Carl
Sep 28, 2008 | Panasonic KX-T7633 Corded Phone
Radio Communications Logo
35 people viewed this question
Top Panasonic Radio Communications Experts
Marvin
Marvin
Lawrence Oravetz
Clint Millett
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
