I have a Canon NP6012
It's flashing an error of E2 and 10 alternatively. I don't want to spend a lot of $ to repair..this machine has been reliable..just use for at home personal use..
Is there a way to fix?
  • Helen0281 Dec 02, 2008
    How would I get the glass off?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
E210 is a lens problem
1- check the lens make sure it is moving, turn off machine take off the glass, move the lens by hand then turn on, does it move ( it is supposed to go to a certain position "home position" and go back )
there may be a problem with the sensors( out of place or bad) or motor (rare)
2- I know that on the older Canon (analog) the lens are moved by a pully/wire, and they break you have to repair it by removing the lens. not that difficult but not easy to explain. We use to repair it by adding a paper clip to the broken part saved time a trip back out.
If you are not a tech or very handy consider paying a tech that does side jobs and offer $60.
A mom and pop runs $75 /hr and Ikon $125/hr !!!!! not including parts.
Posted on Dec 01, 2008
  • CheckitRight
    CheckitRight Dec 02, 2008
    there should be a metal plate on the left w/2 screws remove and you can take the glass off. Put it somewhere safe the glass is a special glass that has a smooth surface for the paper to slide on.
Copiers canon np6012 english service manual
hello, you can find the canon np6012 service manual in below link:
http://goo.gl/eH60jS
thank you
Jan 24, 2013 | Office Equipment & Supplies
Have a canon mp 240 keeps flasing P and 3 and the alarm light and on button are also flashing......what the it wont scan it wont print does any one know what this means
When the Power and Alarm lamps flash alternately, and P and number (error code) are alternately displayed on the LED, an error requiring servicing might have occurred.
Turn off the machine, and unplug the power cord of the machine from the power supply. Plug the power cord of the machine back in, and then turn on the machine. If the problem is not resolved, contact your Canon service representative.
Nov 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
My canon NP6012 flashes E001. Copier flashes and
check also the thermal fuse or switch ,no ac supply is coming to fixing heater
Jul 10, 2009 | Canon Office Equipment & Supplies
5C00 error on Canon iP90 printer
The alternate flashing of orange and green indicates a service call error, something that needs to be taken into a canon authorized service facility for repair. 4 alternate blinking of these lights indicates a problem with the purge unit, most likely requiring replacement.
May 21, 2009 | Canon Office Equipment & Supplies
Error message 5200 on Canon printer i965
Sent the printer for repair to the local Canon Service Centre.
Apr 14, 2009 | Canon Office Equipment & Supplies
Orange and green lights flashing alternately
If the light is orange and green flashing alternately, there might be a service error that requires your printer to be repaired. There might be an error message display.
check your ink cartridge if it is properly installed.
or
If it still doesn't work visit your local dealer or a computer repair shop for assistance.
Apr 06, 2009 | Canon PIXMA iP90v Printer
I have a canon eos450 that showsan error99 when on automatic. It seems to be related to the flash being released when going to use the camera. I is fine on the other functionsPV AV etc but not where the...
Error 99 is a generic error code and only Canon can diagnose it. But given that it occurs when the flash is set on, it must mean there is a fault with the flash circuit. You may need a technician to replace or repair the circuit. Alternatively, you could purchase an external flash if the first option turns out expensive.
Mar 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
IX4000. Resetting a Canon iX4000. What is the button combination?
orange light keep on blinking no error message promted on computer
Sep 08, 2008 | Canon PIXMA iX4000 InkJet Photo Printer
Canon np 6030
Replace the exp lamp and try again after an error clear.
Jun 25, 2008 | Office Equipment & Supplies
184 people viewed this question
jasbo
jasbo
