Question about Nikon N65 35mm SLR Camera
Flash The flash is not pop up on the Nikon N65? When you press the button this error shows on the screen FEE.
  • 95 Answers
You might not have your lens set to the minimum aperture setting (the largest number) if it is a non-G lens.
Posted on Dec 18, 2008
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Nikon d3100 flash wont pop up
If camera shows no sign of abuse, play st-pid and take it back to where you bought it and tell them unit is defective and you want to exchange it for a working model.
Jun 19, 2017 | Nikon D3000 Digital Camera
How can i turn the flash off of my nikon n65 camera?
In the PSAM modes the flash won't pop up on its own. In the AUTO and vari-program modes, you can set the flash mode by turning the command dial while pressing the flash sync mode button (marked with a lightning bolt symbol). Select Flash Cancel (lightning bolt in a circle with a slash through it).
If you need a manual, you can download one at
Dec 22, 2010 | Nikon N65 35mm SLR Camera
The batteries are dead on my N65, but when I pushed the button that pops the flash up, nothing happened. Wondering if that is because of the batteries or if the flash is stuck/broke?
Battery is needed to unlock the catch then the internal flash will pop up. These cameras are programed to automatically pop up in certain modes so there is a little electric switch used not battery no switch. Don't leave the dead battery in the camera or you'll end up with more problems then just replacing the batteries.
Dec 10, 2010 | Nikon N65 35mm SLR Camera
I bought a used Nikon coolpix 5700, worked fine for awhile, but now when I turn the camera on and press the release button the flash will not pop up or work, in the view screen the "SB" shows in the view...
You don't state whether this happens all of the time or only when the flash is active.
If only when active, then the user manual for your camera states that this indicates the flash on your camera is charging and that if you remove your finger from the shutter button it should clear (p.168). In practice it should also clear with the flash is in the retracted position and the flash function is turned off. If it's due to an actual fault then it can be caused if the capacitor or the thyristor charging circuitry has failed. If so it's uneconomical to repair.
If this is the case, then the cheapest and quickest fix will be to disable the pop up flash in the menu (user manual p.95, Set Up 2 > Speedlight Options > Pop Up > Off) and to then use an external flash unit. This also has the advantage of giving you a far more powerful and better quality flash unit.
If the error message occurs whether the flash is retracted or not, then there's a fault with a tiny button switch which senses when the flash has popped up. As your camera is about eight years old now this will be completely impractical to repair and you can only hope that the camera will ignore it if you disable the internal flash as indicated above.
I hope that you have found my answer to be of use; please remember to take a moment to rate my answer.
Feb 13, 2010 | Nikon Coolpix 5700 Digital Camera
Nikon N65 won't take picture
The problem is, that you have a lens witch has an aparture ring on it and some exposure modes needs it to be fixed on the smallest aparture (e. f22). When its done the camera should not say fEE no longer.
May 15, 2009 | Nikon N65 35mm SLR Camera
My Nikon N65 flash leaves a dark spot on all my photos
I love that camera. There are several possiblities, If you are using the pop up built-in flash with a telephoto lens or a lens hood you'll get a shadow in your photos ususally at the bottom of landscape oriented shots. If you are using a flash unit attached it may have something interfering with the strobe possibly or it is turned. We have the same camera and have had the shadow issue in the past. The pop up just won't work if something is wrong with the "bulb" the only other thing is that is isn't going all the way up, check that also.
Jan 13, 2009 | Nikon N65 35mm SLR Camera
N65 built-in flash not working
Yes, you can. Unfortunately Nikon is so backed up with repairs, your camera will probably take a few months to get it back and cost you more than you want to spend. The labor is what is so much. Just like fixing your car a shop. Your camera probably has a flash sensor that has worn out or needs to be re-callibrated is all. I have a friend who fixes cameras.
Check it out
Jan 05, 2009 | Nikon N65 35mm SLR Camera
Nikon Pop-Up Flash stuck
I would not lubricate anything on a camera if you are not a camera repair man. The last thing you want is liquids working there way into places they don't belong.
It sounds to me like you may have a worn part. If someone advises you do do any disassemble to make the repair, don't. Take it to a camera repair man. I know of what I speak! In the 60's, a screw fell out one of my lenses for my Nikon F Photomic. To replace the screw, I had to first remove another part. By the time I finished, the whole lens was in pieces on the table. It cost over $150 to fix (1965 dollars). The repair man told me that if I had left things alone and brought the assembled lens and screw in, it would have cost $10 for the repair.
Nov 02, 2008 | Nikon N65 35mm SLR Camera
FEE reading on n65 camera
Make sure your lens has the aperture ring to the minimum f-stop number, i.e. (f-22, f-32, largest number) and the focus switch set to 'S' or 'C'
May 24, 2008 | Nikon N65 35mm SLR Camera
Nikon N65 35mm SLR Camera Logo
103 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
