Question about Cameras
Cannon sd 500 error 18
I have the camera apart-what to a ''fix.''
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, on most Canon digital cameras, error code "18" would indicate that the lens would not retract/extend. This refers then to a mechanical fault in the lens gear assembly (bellows claw). Actual repair involves re-seating the gear and the locking plate that hold it in place, In some instances, this could be caused by lubricant that has gummed up. Below pages may be of further insights:
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 29, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    President:
  • 1,952 Answers
Tried this with S500....and my camera is now in a million pieces...if you do this be very careful when disassembling the lens because the parts can easily break. Now the lens slider mechanism does not work at all. Its a little bit more complicated with the later models becauses some ribbon cables are saudered and easily break...plus disassembly is a bit different....but should work if you are very cautious...label all screws.. Good luck!!! If can get a hold of lens paper it is better than cotton swabs for cleaning the lenses.
  • 146 Answers
More Specific Please
Name /Model #
Cannon SD 600 lens error restart camera
Go to this website for the solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 26, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
I Have A Cannon Camera. And It Wont Turn Back On!
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 17, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
What does error code 00400 mean
Moultrie told me they could not fix the camera. I removed the Lexar 512 SD card and re-ran the test. The test passed and the camera worked. I replaced the Lexar SD card with a Cannon SD card and reran the test. The test passed and the camera works. I put the Lexar SD card and got a 00400 error message. Change SD cards. It fixed the problem for me.
Aug 31, 2009 | Moultrie MFH-DGS-200 Digital Camera
The lens on my Cannon SD sure shot wil not close
Lens errors are fairly common for all digital cameras. Usually it's sand (be careful at the beach) or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 08, 2009 | Cameras
Hi whenever I take photoes on cannon powershot sd 500, 5.1mp the image is getting blurred and horizontal stripes appear
This looks like a processor fault, or an internal RAM fault. You should send the camera back to Canon for service.
Jerry G.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 30, 2007 | Canon PowerShot S2 IS Digital Camera
Help please
I'm assuming you have a lens error which is giving you the restart message.
It is kind of misleading, but to restart the camera means to power cycle the camera or remove and reinsert the battery.
If you do have a lens error, if restarting the camera doesn't work, you'll need to get the lens fixed if to remove the error.
Dec 17, 2007 | Canon PowerShot SD600 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
