Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer WAS working, but now, it won't work. IThe settings appear to work, since all the lights light up for the various setting. I then press "Start" and the the door locks for a moment, then the door lock light turns off, and the washer refuses to work.
  • i_unpingco Nov 30, 2008
    I just figured out that it's the heating element. There's an Error 68, and the Tech Manual tells me I need to test the resistence of the heating element and make sure it's 14 Ohms. Since I'm not a technician and definitely not comfortable dealing with those types of components, I just need to call someone to fix it. Thanks for the comment, though.
    For everyone else, the list of Error Codes are in the TECHNICAL manual, not the OWNER'S manual.
    Sergeant:
    Champion:
  • 311 Answers
The control is most likely bad. If lights flash on front let me know which ones and how many as it will sometimes tell me what the failure is. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Frigidaire Affinity ATF7000E Front Load Washer locks the door then it doesn't start. What's wrong?
Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
Is door sensor bad if the door lock switch is not lighting up?
I understand that you want to know if the door sensor is bad if the door lock switch is not lighting up on your Frigidaire Affinity washer, model# ATF7000E. Just because the light is not lighting up does not mean that the door switch is bad. It could possibly be that light that is not functioning correctly. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine whether it is the lock or the light. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why some on my cycles wont work nor my light s will light up on my affinity to load washer
I understand that some of the cycles will not work on your Frigidaire Affinity washer, model# ATF7000E. I also see that the lights won't light up either. I suggest giving your appliance a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. After restoring power start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
Door lock light won't come on
I understand that the "Door Lock" light is not coming on, on your Frigidaire Affinity washer, model# ATF7000E. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Jun 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Sep 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
597 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
