It's not from the speakers, it's not a buzzing. it seems to be the fan motors. noone else anywhere online has mentioned this.
Yours is a common problem that Panasonic seems to ignore. The humming apparently comes from the speakers built into the system. The only solution that I know of is to install anti-distortion speakers that have solved the problem for others.
However, before spending any money, I suggest you take a look at a website that explores some of the actions of others. CLICK HERE
SOURCE: Panasonic TC-32LX70 buzzing sound from speakers
You may have rerouted your cable too close to a live connection. The magnetic field from the power line is causing interference on the television cable. You will need to either reroute the cable or shield it from the interference. This can be done with a metal covering separating The wires from the cable. It can also be caused by a bad ground connection in the house. The bad ground will allow noise to appear on the ground of the cable and interfering with it. Check to make sure you have a good ground connection on the cable and the power cables connections. I hope this information helps you with your problem.
SOURCE: Got a humming/ buzzing sound
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
