Question about Pyle PT-3200 Amplifier Car Audio Amplifier
Amp protection mode
Hello. My Pyle Pro PT-3200 has been having problem playing the left speaker after a friend drop a drink in it. I'm fairly good at figuring things out, so I opened it up and checked the two fuses on the left. They looked OK, but after comparing them to the ones on the right, they appeared bent like they started to melt. I'm guessing changing all of them should be a first step... Anybody with other suggestions, please? Thank you! jdor
  • Jacques Dor Jul 08, 2007
    Some parts (Out Transistors) of my amp needed to be replaced indeed. I got it to a shop where they fixed it. Thank you much!
    Novelist:
    Champion:
  • 219 Answers
Try swapping the "bad" fuses for the "good" ones and see if that helps. That will tell you if the fuses are the problem. I doubt that is the problem. You never said what kind of problem you were having with the left speaker. If your friend dropped a drink into the amp then I would discontinue using it until it was checked out and don't be surprised if you have one channel that has some parts that need replacing, like some of the output transistors/MOSFET's. That might explain why your fuses appear to be melted. Maybe they are. In any case, get someone who knows what they are looking at to have a look see at your amp.
Posted on Jan 17, 2007
SOURCE:
Why is my pyle pro pt 2000 burning the fuses
When using this type of amplifier, especially to run subwoofers, you need to use a capacitor of at least 1F in value across the power input. Large capacitors counteract the effect of voltage drops caused by audio program elements such as heavy kick drum beats or other low-frequency spurious elements, and can save your car alternator from being damaged as well.
May 19, 2015 | Pyle Car Audio & Video
Pyle troubleshooting
probably something wrong with speaker
Sep 08, 2014 | Pyle Pro PPHP106A Powered Two-Way PA...
Pyle 2210 how to test the amp when it keeps goin
when the amp goes into protect mode, it is more often than not a problem with the speakers or the speaker wiring.
Sep 01, 2014 | Car Audio & Video
What is the main tranformers number for pt-3300pyle pro
It will be written on the transformer, but you will only be able to get an exact duplicate at Pyle.
May 08, 2014 | Pyle Pt3300 Amplifier
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
Mac is not recognizing the Pyle Pro PPR 80
Same here! Have you figured it out? Im running 10.6.8
Sep 17, 2013 | Pyle pro Ppr80 Digital Portable Stereo...
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
My new Pyle Pro PT-1201X amp has a continuous protect(fault light after just 2 uses. The amp will still pass a signal, but it has to be turned almost all the way up. I checked the audio circuit for shorts...
Its possible that the (((amps the components on the main circuit)) is short this is why you need to turn all the way up, or the pre amp unit.
you need to be more experienced to find this problem
if you want to fix the amp let me know
ecrdn@yahoo.com
Jack
Oct 15, 2010 | Pyle PT1200 Amplifier
Car Audio & Video Logo
117 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
