Question about Dishwashers
Grinding noise from my GE Quiet Power 1 dishwasher
I recently moved into a 2 y.o. previously owned home. The dishwasher is a GE Quiet Power 1 model. After being in the home for 2 months, the dishwasher suddenly started making a low hum/grinding type noise. It's not continuous, happening intermittently regardless of where it is in the wash cycle. Also, when it occurs, it oscillates - grrr, grr, grr, etc. rather than a continuous grrrrrrrrrrrrrrrrr... Thought it might have something to do with the ''bearings'' in the spray bar???
  • 2 more comments
  • CHARLIE MAULDIN Dec 01, 2008
    The owner's manual and online diagrams don't give a clear description of how the washer arm is attached, so I tugged on it trying to see how to detach it to clean possible residue. I wasn't successful (yet) in safely detaching it. However, just the action of torqueing the arm must have had some effect. The noise stopped and hasn't been heard in several subsequent usses. I really appreciate the rapid response to my question and think it has me on the right track. If you can point me toward instructions for removing the washer arm, that would be great. Thanks very much for the ideas.
  • mrdrfreeze Dec 06, 2008
    Yes mine makes the noise had the thing apart two times cant find the problem.
  • Pastorjdh Apr 15, 2009
    Same problem here! No solution yet
  • ward2006 Apr 19, 2009
    same dishwasher house 2 yrs old and neither washer arm works any ideas on the problem?
Solution #2 by user dwdamron is accurate. I checked the docking nozzle and sure enough the o-ring was gone. replaced the upper wash supply tube with new o-ring and problem was fixed.
Posted on Mar 30, 2010
  • marshymay Apr 03, 2010
    I have also found that a rubber band stretched around the nozzle and doubled up a few times is a really cheap fix!
  • arkrube Jan 06, 2011
    AWESOME! Nice troubleshooting and fix....I, too, folded/doubled a simple rubber band around the "male" part in lieu of an o-ring...worked like a champ! THANKS!
The sound is almost always caused by a worn docking cone “O” ring on the main conduit. When the docking cone “O” ring wears, the mid level spray arm conduit is no longer constrained and it can vibrate against the docking cone, making the “growling” or vibrating sound. The recommended repair for this problem is to replace the titanium or gray docking cone.
Posted on Feb 03, 2010
Some scale buildup within the mid level cone and the conduit it docks with removed but I did not see an o-ring. After reviewing a parts list it doesn't appear that there is an o-ring available. After scraping the buildup off both pieces I used a rubber band on the conduit piece and it seems to have solved it at the moment. I did notice a bushing available for each sprayer (top, middle, and bottom). Very low cost parts so I will add those pieces as well as try to find an o-ring to place on the conduit.
Posted on Apr 15, 2010
  • 487 Answers
Might have also something to do with limescale build-up in the washer arm itself.
Makes ballance off and can creat the noise. If it is clean you might check the filter and pump for any dirt build-up
Posted on Nov 29, 2008
I also had success with replacing the O-Ring. I took the hang clip off of the top drawer, then I removed the tube that leads to the spray armature. (first remove the spray armature screw in the center). Then I slid the O-Ring from the other end so it fit snugly on the flange. Perfect fit and no more rumbling noise! Thank you all for this simple solution...
Posted on Sep 09, 2012
  • DGS Sep 10, 2012
    any chance you could send a picture of the O ring you replaced? many thanks!
I tried new o rings but that didn't fix it on mine. What fixed it was cleaning out some egg shell debris that were completely plugging/clogging one of the spray arm holes/nozzles.
Posted on Sep 01, 2012
It's the O-Ring!!!
Posted on Jan 29, 2012
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Noisy dishwasher
    It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
    Feb 26, 2010 | Frigidaire Dishwashers
    Dishwasher has a 'grinding' sound when washing...but doesn't do it all the time..G.E. Quiet Power2, model #GLD800L00BB, Serial #AL794192B (about 3 years old)
    Not interested in setting up an account with you...can't afford it. lease delete our account. We will be replacing the dishwasher with our income tax return. Thanks, anyway. I have recommended your site to others.
    Jan 02, 2010 | GE Dishwashers
    Makes growling noises throughout the cycle.
    HI. here are the most common issues that will cause a noise during the wash.
    * Check the spray arm for damage and obstructions
    * Check the inlet filter screens
    * Test the water inlet valve(see below for test procedure)
    * Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
    * Check the fan motor and blade
    * Check the drain for obstructions
    NOTE
    If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
    Sep 25, 2009 | GE Dishwashers
    GE Dishwasher makes loud banging noise
    Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
    Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
    Apr 06, 2009 | GE Dishwashers
    Grinding
    noise probably not from there when reassembled the plate will not be direct contact with screen noise is probably from wash motor itself..suggest checking owners manual for warranty info
    Aug 10, 2008 | Dishwashers
    Grinding noise for maytag quietseries 200 usually when it first starts up
    I had the same problem with my Maytag Quiet Series 1 dishwasher until I read the comment left by the guest on June 1, 2008. I tried his suggestion about the rinse cap adjustment and WOW it WORKED. No more growling noise. Thanks you saved me a service call.
    Apr 06, 2008 | Dishwashers
    GE Adorda dishwasher
    This one is a known issue and an easy fix. Use a tie wrap to securely tie the water tube for the middle spray to the upper basket. That's it. Believe it or not, it's that simple. You may want to secure it at the front and the back. To test this you can use the tie wraps used to closed the plastic grocery or bread bags. If this solves the problem you can buy a bag of nylon tie wraps from any hardware store. I had a similar problem with another GE model with a similar problem. The dishwahser used to make a horrible grinding noise during the wash cycle. One I secured the middle sprayer arm the grinding noise went away.
    Sep 20, 2007 | Dishwashers
    Dishwashers Logo
    3,945 people viewed this question
    Top Dishwashers Experts
