Question about KitchenAid 24 in. KUDG25SH Built-in Dishwasher
Setting cycles and turning dishwasher on
All of a sudden the child lock was on on my dishwasher. I read the manual and got it turned off. Now, I can press one of the cycle buttons; i.e. "soak and scrub" but cannot press a second one; i.e. "super scrub" -- and the start button will not depress or start the dishwasher. I can press "cancel" and it will cycle through the draining fine -- but, then I cannot set the cycle or start the dishwasher. I do not know whether the child lock being on has anything to do with this problem.
    Scholar:
  • 76 Answers
Frenda Most likely the problem with your dish washer is shorted one or more pads on the key panel. To fix it the key panel has to be replaced. If you'll provide the complete model number and color for the control panel for your dish washer, I can help you to find the best deal on this part. Gendos
Posted on Jan 20, 2007
SOURCE:
My dishwasher is locked. This has never happened before. How do I unlock it?
It's probably still in a work cycle. Advance it to the end, or wait for it to finish.
Jun 14, 2017 | Dishwashers
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
The child lock engaged when a circuit breaker triped. I tried pushing the Rinse Only pad as per the manual. But, the dishwasher remains locked (light on) and won't run.
Hi Gayle, thank you for allowing me to assist you!
When the Child Lock light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, try resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. Select a cycle and your dishwasher should resume normal operations. I ask that you please follow up with a comment on the post, at your convenience to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Sep 27, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Bosh wishwasherhow do you unlock the child safety lock?
Hello there and welcome to fixya The child lock function of your Bosch dishwasher prevents accidental program changes and stops children playing with the controls while the appliance is running. You might want to turn the lock off if it has been accidentally turned on. The controls of the dishwasher are disabled, preventing you from starting a new wash, while the child lock is running. The lock is simple to turn on and off, as necessary, in just a few seconds
Read more: How to Get the Child Lock off a Bosch Dishwasher ' eHow.com http://www.ehow.com/how_12069321_child-lock-off-bosch-dishwasher.html#ixzz2E7bFXnhs
please feel free to give me a rating if this works for you it helps me give you the best help i possiabley can ok
Best regards Mike
Dec 04, 2012 | Bosch SHU9915UC Dishwasher
Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
Dishwasher won't start and control buttons don't do anything.
It would have helped if you provide the Dishwasher model.
HOwever, I am assuming you have the power connected and inlet water is turned on.
It is likely the child control button might be enabled. CHeck dishwasher manual to show how to disable child lock.
If this is not the problem, then assuming your dishwasher has this feature, try to hard reset the dishwasher to factory setting. This is usually done by pressing 2 buttons (depending on dishwasher) together for a specific time. Or in some cases the mains power is turned off and on within a specific time.
Please post a comment to indicate your observations and model no. Please do not rate this solution until I have got some more details of your dishwasher problem.
Jan 17, 2010 | GE Dishwashers
Grandkid palyed with buttons while in a cycle now when you put it to wash it just beeps and the light turns red
might have set the child lock button. If you have the manual it explains how to disable child lock
Dec 30, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
A child lock is flashing with a red light and i do not remember setting it to lock. How do I unlock?
To prevent children from accidently changing the dishwasher cycle or starting the dishwasher, lock the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. An indicator light on the lock graphic touchpad will illuminate when the controls are locked and no new selections can be made until the lock is released. To unlock
please furnish the brand and model no of your dishwasher to be more sopecific
please rate this answer the controls, press the DELAY TIME icon until the indicator light goes out.
Jul 07, 2009 | Dishwashers
Have a whirlpool dishwasher and water standing in bottom
Hi!
Please check and make sure handle link is properly seated in door latch assembly and then check that the door switch is opening and closing properly.
Check the child lock, if it is “ON” then turn it "OFF"
Review setting of wash cycles as per the instructions given in the User/Owner manual.
Now check the circuit breaker or fuse.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 06, 2009 | Bosch SHV4803 Dishwasher
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid 24 in. KUDG25SH Built-in Dishwasher Logo
161 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
