Question about Zanussi ZWF1430W Front Load Washer
Machine stops and goes to end half way through a cycle
I have a zanussi zwf1431 maching and when i put it on to do a load it will wash but skip's the rinses and spin and i have to then put it onto a rinse and spin cycle has any one any ideas what the problem could be.
  • handwashing Dec 06, 2007
    It goes through the cycle until the drain section of the programme then it gives out error code e20. If I drain it manually it continues but how do I get it to drain itself?
  • 183 Answers
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Posted on Sep 01, 2007
SOURCE:
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
No agitate/no spin/yes spin in rinse
this is a drive shaft issue. this shaft is connected to the gear case and the gears may be stripped or the clutch may be damaged. there are many plastic parts here in this area that can break due to heavy load or just old age. replacing the internal parts and clutch will fix these issue you are having.
Mar 13, 2009 | Hotpoint VBSR3100D Top Load Washer
Zanussi Model FLA 1002W Washing m/c.
my w.m. is very noisy, after cycle laundry is with black spots on and white bits on clothing but it is not tissues. ?
Feb 13, 2009 | Zanussi FLA1101W Front Load Washer
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Machine will not empty or rinse
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Aug 27, 2006 | Zanussi F1045W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
625 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
