Question about SanDisk 2GB microSD Memory Card
4gb sd card
My pocket pc will not recognize the card, user guide says to check the instructions for the sd card, but none came with my sd card. how can i get it to work in the pda
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    whats the model of pocket pc?is there a small switch to the side of the SD card?
  • 64 Answers
Some (like my iRocks IR-5300 adapter) won't recognize cards over 2GB. Check the spec on the pocket PC.
Posted on Dec 09, 2008
My IPAC hx2790b will not recognise my 4gb sd card
PCM, Backup the data on the card to a computer. Format the card. Try on your iPAC. If still not recognized. the format in a different computer. Try on your iPAC. Repeat the process till it is recognized by your phone. When and if you get fed up of trying, throw the card away as useless/unusable.
Jul 04, 2011 | HP iPAQ hx2790 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
My new 4gb sd card does not register on storage display, and does not seem available to use
The official oprating systems of the HX4700, WM2003 and WM5, do not support SDHC card format. Since most 4Gb "SD" cards are in SDHC format (check the label on your card), the file format of your card is likely to be incompatible with the PDA. Get a 2Gb SD card, or go for a Compactflash card for 4Gb to 32Gb of storage space.
Jan 16, 2011 | HP iPAQ HX4700 Pocket PC
Mitac Mio 168 Digiwalker cannot recon SD card
your SD might be and SDHC or larger that 4GB. try to use a FAT32 formatted SD, no bigger than 4GB
Sep 04, 2009 | Mitac Mio 168 Pocket PC
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Sd card
The e310 Chipset is SD only, and so does not support SDHC for more then 2GB. You may try non-standard, non-SDHC 4GB cards which are out of specification for SD, but work in "some" SD enabled devices. Depends on device-software...
Oct 17, 2008 | Toshiba e310 Pocket PC
HP5550 Storage Card
The HP h5550 is a bit old PDA , and it cant recognize it.As i know , there is actually no way to connect it.Sorry.
May 09, 2008 | HP iPAQ H5550 Pocket PC
HC SD card support for pocket pc
Unfortunately, Pocket PC devices with Windows Mobile 2003 OS do not support High Capacity SD (SDHC standard) cards.
However, some companies have created standard SD cards (Not SDHC) with capacities up to 4GB. These, sometimes, not always, work.
I would recommend you to purchase SD cards up to 2GB in size only which is the maximum size the SD standard has defined. If you would like to try the max capacity you can get, you can try some "SD standard extended, but not SDHC" SD cards up to 4GB. If you would like brand names, I could recommend you a few..
Dimitris.
Feb 23, 2008 | LG KU990 Viewty
SD SLOT WONT READ 4GB MINI SD REG SPEED
try the 4gb card in a camera or phone. If the card is formatted in fat, it wont be recognized as the fat has a gb limit under 4 I believe. May want to reformat it in a camera or phone with fat32
Jan 24, 2008 | Compaq Presario X1000 Notebook
SanDisk 2GB microSD Memory Card Logo
113 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
