Question about HP Compaq Presario SR2011WM PC Desktop
Monitor malfunction, says VGA Input: No Signal and goes to sleep
When I turn the monitor on, it says VGA Input: No Signal, and goes to sleep. I heard from an employee at a computer store that it could be the video card. I opened the back of my Compaq Presario SR2011WM to try and remove the video card, but it seemed to be connected with the entire computer chip. I would like to know if the video crd is actually the problem, and if it is, then I need to know how to remove it to replace it with another one.
  • tafox Jan 03, 2009
    We have the same problem however it has been occuring over the past few weeks. After numerouse attempts to turn on it would eventualy work, not we are unable to turn to PC on at all with the monitor going to sleep
  • pklinuxguru
    pklinuxguru May 11, 2010
    I take it this problem suddenly appeared? It sounds like you are right. That model usually has a built-in video card. That probably means it's got to be serviced by the factory. However, if you had a replaceable video card, it would be in one of the horizontal slots that are on the bottom half of your computer. There are two areas where things are connected. At the top of your computer will be the keyboard, mouse and maybe the video plus some USB ports.
    Problem Solver:
  • 10 Answers
If it was your video card, you would have no picture at all. Try to boot in safe mode and do into your options and make sure your hibernation is not on. Only other thing I can think of, it could be *********** board.
Posted on Nov 29, 2008
2 Suggested Answers
  • 135 Answers
SOURCE: Monitor malfunction, says VGA Input: No Signal and goes to sleep
from what you have described it appears that the onboard video might have malfunctioned,there is no way to replace it, you can however go buy a video card from your nearest computer retailer. you just want to make sure it is compatible with your machine. on another note from what your saying the keyboard is donig i would be wary about spending to much $$ because it could also be your motherboard
Posted on Apr 23, 2009
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
I loaded Windows 7 and now when I turn on the computer, the monitor says DVI input no input signal and goes to sleep. Can you help?
Do you have the correct driver loaded? Are you using DVI output on the computer? Is there a VGA output? If so, try using a VGA cable while you troubleshoot the video issue.
May 11, 2011 | HP w2207 Monitor
Monitor goes to sleep when computor is turned on no input signal
If the monitor is going into sleep mode the normal power led will change to another color. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays on, you have a backlight malfunction. It can be bad capacitors causing an inverter power fault or it may have worn out backlights causing a shutdown condition.
Monitor Mike
Aug 17, 2010 | HP w1907 LCD Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Apr 23, 2009 | Computers & Internet
Monitor goes to sleep no input signal only 1 mo old
Normaly the monitor is not picking up the signal from the PC, it could be VGA cord is not connected, faulty, or the video card is faulty,or the monitor is not compatible to the PC. It could be one of my suggestions. Trouble shoot by connecting your monitor to another working PC and see what happens.If not the VGA cord is faulty and not picking up signal from the PC. Hope it helps.
Jan 21, 2009 | Computers & Internet
HP Compaq Presario SR2011WM PC Desktop Logo
1,560 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
