Question about JVC RV-B99GY Cassette Boombox
Display light out
I've had my boom-box for quite a few years and never had an issue. But suddenly a year or so ago the light in the display went out. At first I thought maybe the cords weren't in all the way or it was the batteries. I checked everything and still nothing. Since I wasn't sure what the problem was I tried not to worry about it and deal because everything else worked great. Lately my eyes have started to go bad and I have trouble reading things far from me, which the boom-box is. Now I really wish the light would work so I could see what was going on without having to be almost on top of it to read it. Anyone with ideas of what the issue could be? Should I continue to just "suck it up" since everything else works? Or should I throw in the towel and grab me a new one? Thanks in advance for any help I receive.
Re: Display light out
I have a JVC Kaboom RV-B90GY. Been working ok, then one day, no power. WOuld you know the problem. I hate to junk this guy as it's a good machine.
Posted on Jun 27, 2009
Hello, I've had JVC RV-B90 Boombox for few yearst too, but display lighting is ok, There is just small bulb, so take it apart and just change bulg for new one. Good luck !
Posted on Nov 02, 2007
0 characters
3 Points
ILive iBC233B LCD low
no there is not an adjustment for it..
Jun 25, 2014 | iLive IBC233B - Ibc233b Bluetoothr Boom...
I have 2 boom boxes where cd's spin but no sound.
Its probably a lens failure, its quite common, try cleaning the lens,
if all else fails, try turning the unit upside down and load the disc, sometime this for some reason - resets the lens if slighty out but its not fact, just something i heard
Jan 22, 2014 | Sony Boom Box With CD Player & Cassette...
After two years of daily use, the Bloombox BAR201
Have you checked the glass fuse inside the boom box? if thats blown it will be a black brown colour.
May 14, 2010 | Emerson Barbie Bloombox BAR201 Radio/CD...
Same error on 3 boom boxes caused by one audiobook
Well if they were cheap then they were made in china, they fail prematurly due to cheap parts and poor build quality. CD's dont make Cd players break down unless they are caked in dust or are damaged.
May 11, 2010 | Panasonic RX-D12 Cassette/CD Boombox
My Sony CFD SO1 keeps skipping/display light keeps flashing
That is an electronic problem. Probably a just-about-to-break cable in the motor of the CD drive, that sometimes causes a short and turns off the unit, or sometimes makes it to comport erratically and produce the buzzy sound. If you have electronics knowledge, then you may open and check the wiring harnesses. If don't, take it to your local electronics repair.
Nov 20, 2009 | Sony Boom Box With CD Player & Cassette...
I need to add outdoor speakers,and the headphone
I would run the headphone jack to an amp then hook up you outdoor speakers to the amp.
Oct 07, 2009 | Sirius SUBX1 Universal Plug and Play Boom...
Jvc rv-dp100 boom box
tune into the station you want as normal. Then on the remote, press & hold the number key for the preset number you want. This will flash in the display to show you it's set. You can preset 30 FM & 15 AM stations.
Sep 17, 2008 | JVC RV-DP100 Cassette/CD Boombox
Cd player on boom box
Hi I don't have a boom box, but i do know a little bit about CD players, and i think first the CD you are putting into the player as to be a proper bought CD, you know official CD, if you have done that, and still have the same problem, then its because the laser light is faulty, which basically means the CD player needs replacing.
Jun 10, 2008 | Boomboxes
Digital Display
Last time that happened to me I moved it to a different outlet and it went back to normal. a couple of days ago this happened again though, and nothing i've tried has worked so far.
Oct 08, 2007 | RCA RCD158 Boombox
JVC RV-B99GY Cassette Boombox Logo
664 people viewed this question
Top JVC Boomboxes Experts
Jonathon summesfield
Jim Oliver
Jim Oliver
Level 1 Expert
Are you a JVC Boombox Expert? Answer questions, earn points and help others
