Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Ip address,subnetmask,primary dns,secondary dns,default router,
I need these 5 items,to manualy set up the internet through my d-link wireless router.for my play station 3 game system. model-dl-634m
  • 488 Answers
They should be given by the internet provider or you can try the following:
on a computer connected to the internet..go to the run menu(windows key and r key)
type cmd
a command prompt will open
in that type ipconfig/all
hope it helps!
Posted on Nov 29, 2008
Im try to get internet on my psp netgear please help me
Posted on Sep 03, 2009
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
My laptop wont connect to my wireless router, it just says acquiring network address all the time, it does connect to other wireless routers though?
To connect a laptop to a wireless network for accessing internet....you have two ways:-
1. DHCP (Dynamic Host Control Protocol) 2. Manual entry of settings in wireless adapter properties.
1.DHCP:- In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network router settings.
2. Manual entry of settings in wireless adapter properties. This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
* IP address (Its format is "xxx.xxx.xxx.xxx") * Default gateway address (very important) * Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast) * Subnet Mask (not needed mostly...automatically generated)
To enter these settings you have to rightclick the Wireless Adapter>> and select properties>>Then double click the Internet Protocol version 4(TCP/IPv4) and enter these settings. In many cases when you are using proxy server then you have yo use proxy settings also in your browser..
Hope this will help 4 sure....Cheers..:)
Sep 30, 2010 | Acer Aspire 3610 Notebook
Need to set up wireless router
you have two ways:-
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
  • IP address (Its format is "xxx.xxx.xxx.xxx")
  • Default gateway address (very important)
  • Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast)
  • Subnet Mask (not needed mostly...automatically generated)
Sep 25, 2010 | NetGear WNR2000 Wireless Router
Need help connecting wireless router
1.DHCP:-
Hope this will help....Cheers..:)
Sep 25, 2010 | Computers & Internet
Sylvania netbook cannot find server or DNS Error I just bought this netbook and I followed the wireless netbook connection directions. When I click on the internet explorer icon it immediately says "The...
Hi PROBLEM FIXED!!!
I had the same problem but fixed it! its simple, go to network and dial up connections in control panel and change your internet adapter card to obtain ip address via dhcp. to do this just double click on it or right click and change the properties. if you are not sure which one is your wifi adapter just do it to all of them till it works. also make sure u have set up yr encryption properly.
Sep 06, 2010 | Sylvania G-Netbook
No Internet access
make sure you can access the router configuration page
change you computer ip addess to match the ip address range of the router
ex if router is 192.168.1.1
set computer ip to 192.168.1.2
subnetmask 255.255.255.0
and set default gateway and dns server address to gataway address
geateway 192.168.1.1
dns server 192.168.1.1
try it most probably you need to make sure you have configured your adsl user name and password and other settings in you router since you have rested it
Apr 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Router
the dns setting is the same as your routers ip address
Sep 07, 2008 | Linksys Wireless-G WRT54G Router
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
2,609 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
