Question about Texas Instruments TI-83 Plus Calculator
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I have the same problem as Woodt3. I never have dropped my 83 but half of the screen towards the bottom has lines going across horizontally so I see the upper half of the calculator clearly. I can still perform calculations, and they are mostly obscured by these lines. What is a suggestion to fix the problem with the lines going horizontally through the calculator screen?
  • peak7 Jul 23, 2008
    All buttons seem to work fine, but the screen displays vertical lines throughout the screen and obscures solutions. The right half of the screen will not clear with the clear button. I've tried removing all batteries and clearing memory, but that doesn't change anything. Is there a way to reset the screen or calculator. (TI-83 Plus)
  • Anonymous Oct 31, 2008
    There are one bold vertical line and many tiny horizontal lines blank on the TI83 screen. The functions on the calculator seems to be fine except the display screen.
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Posted on Sep 18, 2009
I've had a similar problem in the past with my TI-86. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons every few minutes.) One time it was so severe that I had to do it for about 15-20 minutes. It works great, and the calculator is fine unless you leave it unused for a month or so. One thing that I also found helps is if you type several numbers or something to fill up the screen completely and just use the up/down and left/right arrow keys to keep the calc from shutting off. A similar solution may work for you.
Posted on Jul 10, 2007
SOURCE:
I'm using a TI-83 Plus calculator. Halfway through my screen there is a straight line preventing me from using the top half of the screen. No matter what I do I can only use the bottom half. Is there...
You've got the split-screen turned on. To turn it off, press MODE to open the mode screen. Use the arrow-keys to move to the second-to-the-last line, highlight "FULL," and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Jan 27, 2011 | Texas Instruments TI-83 Plus Calculator
You probably have your calculator set to display the graph on the home screen. Try pressing MODE and going to the last option, then changing it from "Horiz" to "Full". "Horiz" means it is displaying the graph (probably without axes since your screen is otherwise blank) on half the screen.
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
Screen obstruction TI-83 Plus Graphing Calculator
The liquid crystal is damaged. I suppose the screen can be replaced. Check with Texas Instruments resellers (usually academic bookstores): they may be able to tell you where you can have the calculator serviced.
You can post an ad on the college bulletin board
TI83Plus Wanted
OK for batteries to be dead
But calculator must be alive.
Hope it helps.
Jun 28, 2009 | Texas Instruments TI-83 Plus Calculator
My screen on my t1-83 has gone really dark and i don't know how to make it brighter
This means both your Xscl and Yscl values are too small. Fix this on the WINDOW screen, as explained under My screen is covered with horizontal or vertical lines.
Thanks
Fame !
May 04, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 is all messed up
Sorry to hear that you are having problems with your TI-83. The TI-83 is a discontinued calculator, so I really don't think that it can be repaired/replaced.
See TI's website below for more information:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71440&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGEE602C53EA628B70E47DD2DD6878A5ABD632AD5834DE8ADC18D66ABBC9F888CBF7FB517A0B05B0984776B37370A28975B2
Feb 24, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 LCD Screen Problem
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
Aug 14, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
2,583 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
