Question about Gateway GT4010 (RBGT4010) PC Desktop
My computer will turn on, but nothing happens and it beeps at me
When I turn it on, the fans come on, but nothing happens expect about every couple of seconds the computer beeps
  • annepayne Nov 29, 2008
    I just tried that and when I plugged it back in, it started beeping again, do you have any other thoughts? Any help is greatly appreciated
    Genius:
  • 2,785 Answers
Plz try by resiting the ram
Posted on Nov 29, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Dec 01, 2008
    plz try by another working ram
I hooked the ps3 to the philips tv. turned on the ps3, AV1 displays in the corner. Nothing else happens, I am expecting the ps3 logo
give this a try...
Leave the TV running, go over to your PS3 and turn it off.
Once its off, hold the power button down till you hear a beep, KEEP HOLDING THE POWER BUTTON till you hear a double beep. The PS3 will shut itself off.
Give the device a couple of seconds, then hit the power button one last time (just turn it on, you don't have to hold it).
If all went right, your baby is back up and running...
Oct 11, 2010 | Philips 27RF50S 27" TV
My led and keyboard and mouse light up when I turn on power switch, nothing happens when I push start button. My e-mail address is debandeddy@yahoo.com
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Sep 14, 2010 | ASUS P4VP- MX VIA P4M266A UATX P4/...
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself...
hi hope this helps.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Oct 18, 2008 | ASUS Computers & Internet
3 beeps and fan running at start up
The three beeps shows the Memory Module Test and that symbolise that the memory module is having a problem and to my knowledge when there is a problem with the memory then you have to open the casing and remove the memory module and clean the slot very well and if slot in back and the memory do the same change the to the second memory slot if it happens there again then you change the Memory module.
ok
rate this solution.
Oct 06, 2008 | Gateway GT5408 PC Desktop
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
No signal input
Check the coolant between the CPU and the cooler to ensure it's not simply over heated.
May 30, 2008 | Acer AOpen AX 6B Plus (91.87810.321)...
Wont turn on, bios beep code
Seems heat-related motherboard POST failure. Replace it.
May 25, 2008 | Sony VAIO PCV-V210P PC Desktop
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
Asus P4pE not booting.
The beeps you hear are probably BIOS error beep codes. Through a series of long and short beeps the BIOS communicates what type of error is occurring during the initial stages of the start up process. If you can tell me the manufacturer and model number of the board AND the sequence and length of the beeps I can point you in the direction to go.
Dec 13, 2006 | ASUS P4PE Motherboard
Gateway GT4010 (RBGT4010) PC Desktop Logo
486 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
