Question about Yamaha RX-V596 Receiver
Rx v2095 receiver - No sound from either front main speaker
Lately I've been having trouble hearing dialog on DD 5.1 shows/movies. I hear fine when I select "Effect Off" on the remote. As of a couple of days ago, though, when I select "Effect Off" I lose all sound all together.
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Posted on Dec 01, 2008
My RX-V2095 cuts itself off about 3 seconds after I power it on. I have unplugged it from the wall to give it time to reset itself and unplugged all components and speaker connections and still I get the...
Try setting the "Auto Power Down" in the "Setup" menu to "off". Double check the selection of the speaker impedance on the back of the unit to make sure it matches your speakers.
Feb 19, 2014 | Yamaha RX-V2095 5.1 Channels Receiver
Sound is great unless I'm playing a DVD. When I'm playing a DVD, the music and sound effects are fine, but I have difficulty hearing and understanding the dialog. Any suggestions?
Check your setup for the center channel level, or to see if the center channel speaker is working at all.
Also check the setup in your DVD player to make sure its speaker setup matches what you have.
Feb 14, 2011 | Yamaha RX-V750 Receiver
I have a Yamaha RX-V663. I recently upgraded to 7.1, but the 6th and 7th speakers do not activate on DTS HD Master Audio Blu rays. The 6th and 7th speakers do activate on DTS True HD, DTS EX - ES,...
It is unclear to me as to what you mean when you say they do not activate. Does that mean that they just don't play, or does it mean that your receiver doesn't show them on the display? If your not hearing the sound from the speakers, are you sure your dvd movie is capable of outputting 7.1 or is it only 5.1?
If the receiver doesn't show the speakers on the display, try running through the speaker setup again to make sure you selected both sides and rears for the setup.
Good Luck
Jan 06, 2011 | Yamaha RX-V663 Receiver
Poor dialog sound of Yamaha RX-V363
I'm working on one right now. It seams that you are not selecting to correct program for the dialog. I would not use music enhancement on dialog content.
Jul 15, 2009 | Yamaha RX-V363 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Back speaker sound
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Feb 04, 2008 | Yamaha RX-V2600 Receiver
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
Shutting off during a loud part of a movie
Its eather a defect with the reciver top end shut down /over bias system , Or the speakers could be partially shorted, such as instead of being 8 ohms, the speakers could have a few shorted windings from a loud music event?? I would take the speakers in to be checked under load. NOT just checked for resistance.. A regular shop may not know how to do this BUT tell them you need to put the speakers under a load and then measure the resistance . GOOD LUCK
Jun 25, 2006 | Yamaha RX-V550 Receiver
Yamaha RX-V596 Receiver Logo
337 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
