Question about Sony PlayStation Portable (PSP) Console
THE POWER SWITCH
I accidently dropped the PSP and when i went to check if it will turn on, the power switch was very loose and nothing happened when i fliped it up. im probably gonna have to buy a replacement circuit board or something. what should i do to fix the problem without going out and buying a new PSP or sending it to SONY
  • 4 Answers
If it's under warranty send it back, if it's not then do this. Order a replacement power switch online, ebay is pretty good for psp parts. There's 5 screws holding the front cover of the PSP together two on the right that are recessed, you'll need a long skinny precision screwdriver , there's two more under the warranty stick behind the battery and one more in the middle of the silver metal piece. The power stick assembly is a separate board that plugs into the psp and a easy repair. Just be careful once you remove the faceplate one dust particle and you'll be taking it apart again to clean the inside of the screen.
Posted on Feb 07, 2007
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
My psp wont turn on. the amber chargeing light is on, even left for a few hours to charge still wont charge and replaced the battery.
Hi there!
When you charge your PSP with the charger (USB/wall) does the power light turn to amber? If it does not, It's possible that your charger (USB/wall) is already broken. You may need to purchase a new one.
If it does, you may have either a loose power switch (which happens on my PSP Go) or you may need to have your unit checked with a qualified technician.
Hope this helps!
Feb 01, 2011 | Sony PlayStation Portable (PSP) Console
My psp don't switch on, it just shows the green power switch
You might need to reinstall your OS, you can download it from their site onto your PC and install it.
Aug 24, 2009 | Sony PlayStation Portable Slim Black...
Psp ower problem
I had something like this happen to me, but I was lucky enough that it started working again. Try putting it in a bag or container of rice, because rice absorbs moisture, so it might pull any water out of it. Hope this helps.
Mar 21, 2009 | Video Game Consoles & Games
T2893 e machines wont turn on
Since you are looking inside, try this. Trace the wires that come from the power switch back to the Motherboard. The wires from the switch will connect to two pins on the motherboard. Carefully jump those two pins with a screwdriver and the machine should turn on. I would suggest doing this with all drives and cards unplugged first.
Jan 15, 2009 | E-Machines (T2824) PC Desktop
Dropped psp...now it wont switch on
Try this :
Put in the battery, and hold down the ON Button for 10 seconds. Then, take out the battery Hold down the power ON switch and put the battery in while holding the ON Switch... Let go of Power switch, and charge the battery for 10 hours
Try turning it on
Jan 04, 2009 | Sony PlayStation Portable (PSP) Console
Dropped my PSP! Screen Blank!
Well if that`s true that if a handheld is broken when dropped then I shouldn`t have any working handhelds. Well, if you still have the companies number you should call Sony and ask them.
ps, tell them it was your friends.
May 03, 2008 | Sony PlayStation Portable (PSP) Console
PSP will not turn on
hmmm... that sucks. Could be a fried power slide-switch. If no power is getting through the system, even when using the AC adaptor, it's probably something in the power chain.
It might be of benefit if you could try the battery and power adaptor in someone elses PSP, if they both work then it's probably something internal, and it's not unheard of for the power switches to go kaput.
If it's under warranty, take it back. If not, you'll need to have it checked out I think.
Mar 29, 2008 | Sony PlayStation Portable (PSP) Console
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
51 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
