Question about Roland MA 8 Computer Speakers
The 2nd speaker doesn't work
The speaker that is connected to the "power" speaker doesn't play any music although it does do the normal sizzle thing when the music is off and on...I have tried everything that I could think of.....changed the component wires, changed the input wires, shook the speakers (nothing is loose) and thats all i could think of nothin is working for me
  • 1 more comment
  • duane sneed Jan 17, 2007
    Btw the left speaker does work when I put the line directly into the speaker but the sound is faint
  • Anonymous Jan 17, 2008
    I have the same problem, I will try and repair mine
  • duane sneed Jan 17, 2008
    I found when i use the phono jack on the back as an input then both speakers work so It might be something internal with the rca jacks
    New Friend:
Same problem here
...thought about bying a new speaker but /after googeling :this is a common problem now i guess , due to the vibration there is an solderpoint problem .
Posted on Jan 21, 2015
Will try and troubleshoot, mine does the same
Posted on Jan 17, 2008
SOURCE:
Stanmore Bluetooth doesn't work
Not certain what you mean by "cable music" but if works normally on the other, that shows there is a connection problem. Does it connect to this source via a cable? If so I suggest you replace it.
Nov 03, 2015 | Marshall Stanmore Bluetooth Speaker
I installed an aftermarket radio in my car. The car's speakers sound pretty bad when I play some of my music off of my iPod. Is there something I can do to improve the quality or would I be better off...
1st rule of audio, make sure you have a high quality source material, 2nd, make sure you have decent speakers in which to hear that material, 3rd, make sure you have a quality device to play said material, 4th, have sufficient amlifying power to hear the material at the desired level. if you have all these things, you are well on your way to bliss my friend!
Oct 19, 2013 | Car Audio & Video
No sound just video
Okay, a couple of things.
This speaker issue seems to be a common problem, and I believe it most likely occurs due to rough handling of the unit. Although it seems to be fairly rugged, it should be treated gently. In general, I would only handle it as much as needed, and be careful when setting it down, and make sure it doesn\'t get dropped.
With that being said, the unit can be opened, however doing so will break at least some of the "snaps" that hold it together. If it is out of warranty and you need to get into it, this is a necessary evil.
Step one: Remove the battery cover (one phillips screw) and battery. There is a second, smaller phillips screw that also must be removed.
Step Two: At this point, you are ready to separate the unit. Using multiple flat head screwdrivers, pry the unit open (starting on the right side when looking at the unit from the front) then "wedge" the pried open area with a second flathead screwdriver as it will naturally want to close back up. Continue working your way around the unit, being careful not to crack the screen. You will break some tabs along the way, but I see no way around this as they are not visible to try and release them any other way.
Step Three: Once you have separated the two halves of the unit, the power button will have fallen out. This is okay as it will slot back into place when you reassemble the unit. Just set it aside and do not lose it.
Step Four: I do not know the exact failure mode of the speaker, however you will find that it is apparently strongly secured in the housing with an adhesive (epoxy or some sort of resin) and if you had to remove it it would be difficult and not very fun.
MY SOLUTION: I hooked the battery back up and turned on the music feature, which should play music from both the camera and the parent unit. In my case, I found that tapping hard on the speaker (it took more force than you would think) would cause the music to momentarily play. I found that wedging a screwdriver between the plastic housing and the speaker body would make the speaker play. I used a small nail (like a trim nail for small trim) and wedged it between the speaker and the housing, then trimmed off the excess of the nail.
This solution is not ideal, but it was relatively quick and worked to keep the unit functioning for now. I imagine that there is some sort of connection that has failed internally in the speaker, and that wedging it has (at least temporarily) reformed the connection. I imagine that a new speaker could be installed with some work to remove the old speaker, and then a new one soldered in and glued into place.
Once I got the speaker working, I disconnected the battery and carefully replaced the power button, then the two halves simply snapped back together. I replaced the screws and reinstalled the battery, and all has been working as it should. The case does show some damage from my prying, and it doesn\'t fit as tightly as it used to with the broken snaps, but it does hold together and doesn\'t have any issues in normal use.
In all, it certainly beat buying a whole new unit, especially since it was working just fine other than the sound. Good luck!
Apr 28, 2013 | Motorola Mobility MBP36 Digital Video Baby...
How to open the parent unit for motorola baby monitor mbp36
I have the same problema but i cant figure it out how to open the unit.
Mar 26, 2013 | Motorola Mobility MBP36 Digital Video Baby...
Can't get my speakers to work i may have plugged it in wrong
First thing to check is that the power light is on on your speakers. No power no sound
2nd. Power is plugged into the green round jack. (occasionaly in black for digital)
Easiest thing to do is put in a music cd and keep moving the plug until you hear the sound. hope this helps.
Mar 04, 2010 | Computers & Internet
My amp burn one of my 3 subs and i keep playing
You are probably exceeding the rating for the speakers. This amp can deliver 2000 watts to a 2 ohm load. You would need MASSIVE speakers to take this much power. The best of speakers can probably take an HONEST 400 watts... although most LIE big time about their capability. ALSO the spaekers have to have an ENGINEERED enclosure when run at high power. It is unlikely you cna drive 3 speakers evenly so they share the power... one is gonna get fried first...
then the remaining ones will fry...
ALSO make sure you don't send music pitches higher than what the speakers are designed to take. Make sure your crossover prevents highs from getting to subs.
Dec 22, 2009 | Crossfire VR2000D Car Audio Amplifier
How do we connect our MP3 player to the surround sound Logitech X-540. It does not seem obvious. We can connect to get some speakers working but not all..
The only way for you to be able to play music on your mp3 player with those speakers is if you Connect the mp3 player to your PC and play the music threw there.remember you cannot use your speakers for portability it has to be connect to a power outlet constantly in order to work
Dec 25, 2008 | Logitech X-540 Computer Speakers
No sound but system display appears normal
I have the same problem. I'm interested in hearing how it's resolved.
Oct 30, 2008 | Bose Lifestyle 48 System
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Roland MA 8 Computer Speakers Logo
290 people viewed this question
Top Roland Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
