Sound OK but no picture
2 days ago it worked fine on Direct TV. Now only sound. The menu shows green on sleep and off beside it. I an not make a selection change to the menu.
    Problem Solver:
  • 13 Answers
Another intermitent problem, It seem that theres a disable unsoldered part on the chassis that cause of it iether on the Cold side or Hot side.It needs to be trouble shoot.
Normally it gathered from the climate temperature changes
r_ic7
Posted on Nov 29, 2008
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
you might try checking the sap (secondary audio programming) option in your tv if it has one make sure it is turned off. if it is off or does not have that option you will most likely have to take it to a repair shop. i would not try to fix it my self as you will do more harm than good.
Dec 09, 2008 | Insignia IS 20" TV040919 TV
No Sound
first you want to make sure and check if the problem is common for other inputs as well (dvd ,player antenna A or B)
or if you have a cable or satellite box sometimes you may have problem with those too( reset them by uplugged them too)
if evething ok check tv menu and see in audio secction if speakers are not turne off.if still you have a problem the audio amp inside the set its having a problem.
Jul 03, 2008 | Toshiba CF30F40R 30" TV
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
