I NEED TO BUY SPEAKERS FOR MY BOSE MODEL AV3-2-1 MEDIA CENTER
Which speakers do you need the sub or the two fronts?
Watchmon60@aol.com
Posted on Apr 23, 2009
  • 4 Answers
I have a bose av321 series2 gsx media center and satellite speakers and also have cinemate subwoofer need to connect them is it possible
  1. Probably not. Bose has their own laws of acoustics and all eq. and crossover points are done inside. You need a separate crossover component to accomplish this. From a professional viewpoint, we always say BOSE = Buy Other Sound Equipment and the EQ/Crossover/phasing trickery inside every Bose system is a large reason for this.
Nov 15, 2017 | Bose Audio Players & Recorders
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
I have Bose® Companion® 2 Series I computer speakers. I need to replace the adapater and want to know if speakers accept +ve or -ve polarity voltage. Thanks!
Each device is different.
If the receptacle for the plug is not marked, you have few options.
I suggest the following.
Go buy the exact same setup from a store you can easily return it to.
Take the whole box to Radio Shack and explain that you need a power supply to replace the power supply in the box. They will sell you one, plug and all, for about $10-15.
If you have a DVM (Digital Volt Meter), you can check the voltage and polarity yourself, and buy what you need, test it out, and install it.
--Dave
Feb 08, 2010 | Bose Companion 3 Computer Speakers
AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Dec 05, 2009 | Audio Players & Recorders
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
NEED TO PURCHAS
I CAN SELL TO YOU I HAVE THE SPAKERS
Nov 29, 2008 | Bose 3·2·1 II System
Additional speakers for 321 system
No. You would need some kind of audio out connections on the back of the media center. The only audio outs it has are the
Acoustimass® Module – SPDIF connector.
Unless you were to hook up an amp before the Bose media center. In other words, you could run your TV to another amp's line in. You would hook up additional speakers to this other amp, then run audio line outs to the line in of your Bose media center. Some stereo amps have a line out or record/tape out, it is from here that you would run the cables to your Bose media center line ins. The disadvantage to doing it this way is you would have to plug all your media devices (dvd, tv, etc) into this amp first and your Bose remote wouldn't let you switch between devices. If your media devices you have offer digital audio, then you would want an amp that also offers a digital out for the best sound. Otherwise you will end up with analog out from this amp to the Bose media center and thus lose any of the digital signal information like surround information. So there isn't much point in doing this. If your gonna get an amp that has all the digital in's and out's, you might as well just use it with new speakers and forget the Bose system you have.
Jun 06, 2008 | Bose (321GS) System
Av3 2 1GS Media center
Yes, Try Media Receive Ltd - 0845 20 20 118
Dec 14, 2007 | Bose 3·2·1 GS II System
106 people viewed this question
 Grubhead
Grubhead
