Question about Rival CF300 Deep Fryer
Putting it back together
We put it back together but it wont heat up?
    Genius:
  • 1,036 Answers
Check the element connections are clean and making good contact. If they are all plugged in ok, it may have developed a fault during cleaning. This may be the thermostat or element that is faulty.
Posted on Nov 05, 2008
Cuttlas Ciera Wont Turn Over!!!
Sounds like it seized when you shut the engine off after driving it while overheated.
Jul 10, 2014 | Oldsmobile Cutlass Ciera Cars & Trucks
2004 grand caravan: heat but fan wont push air
Need to remove fan and test it on a bench by connecting it directly to a car battery. Removing items like this buried in the dash takes a long time, and its tricky to put back together.
Dec 14, 2013 | 2004 Dodge Grand Caravan
1986 25 hp johnson just removed lower unit put back together and now stuck in foward wont go into nutral or reverse
Check Srew Pivot Pin On Side Of Gear Box !
Sounds Like It Has Missed The Shift Cam Pivot Point
You Should Be Able To See The Whole That The Pin Should Go Into
When It Is Lying on Its Side
Mar 16, 2013 | Boating
I have the Presario F700. it wont turn on.
HP really messed up with some series of laptops that use amd processors and nvidia chipsets like the F500 and F700, in latin america, where I live, they never provided a solution and in the US, Canada and other countries a product call back was made but not all the users were informed and it's no longer in effect, so what you can do is repair your laptop, I'll tell you how.
You will need:
-presario F700 service manual (google it, you'll find it easily)
-heat gun or hair dryer
-a penny
-thermal silicone grease
I know it sounds like something MacGyver would do, but it helped me with several presarios F500 that wouldnt turn on. I'll explain a little so you can see why this actually works. The computer will stop turning on, in some cases wi-fi will absolutely die before,when the computer overheats, to be precise, the nvidia video chip overheats the soldering that holds it in place, when contact is lost the problem appears. So what you need to do is simple, first you need to "re-solder" the chipset, then you need to improve the system to prevent the chip from overheating, thats when the penny is used, as it is made of copper (or so I was told, I'm not american so I couldn't say for sure) it will act as a heat sink for the video chip, copper has great thermal properties.
First thing first, you'll need to follow the instructions on the service manual to dismount the fan/heat sink assembly, be really carefull not to misplace any screw or you'll have a hard time putting all back together. There is a part of the service manual that will require you to dismount the display,carefull, the complete instructions regarding that part will lead you to disassemble completely the display, my advice is, once you remove the screws that hold the display to the rest of the computer you can continue with the top cover (where the touchpad is located).
Once you have the motherboard out, identify and remove the processor as well, the fun begins now, using your heat gun or hair dryer heat the nvidia video chip, thats the one by the processor not the one by the wi-fi card, if you use a heat gun heat it for about 2 minutes you wont need more than that, try to direct the heat only to the nvidia chip, you dont want to de-solder any other components, you can cover the rest of the motherboard with magazines, that helps a little, if you are using the hair dryer make a cardboard cone to redirect the heat to the chip, you'll need to heat it from 10 to 15 minutes depending on your hair dryer, make sure to hold the heat gun or hair dryer at least 4 inches away from the chip, dont apply heat directly.
Once you are done heating the chip, you'll need to press it firmly to put it in place again, you wont feel the difference but simply do it, dont do it with your fingers or you'll burn them, that should do the trick, your computer is now fixed, however if you put it back together just like that it will fail again soon, so we need to improve the heat sink for the video chip.
You need to use the thermal silicone on both sides of the penny, then put the penny over the video chip, as centered as possible and then put the heat sink back on, off course you need to put the processor back on before putting the heat sink back, there is an optional thing to do before putting all the rest back together, you can drill some holes on the base enclosure right where the video chip is located, that will improve ventilation, then follow the instructions to put all back together, after that you can try to turn your computer on and see it turning on like it used to.
This has worked for me several times, I hope it works for you as well, one last advice, update your bios to latest version and get a cooling pad to prevent as much as you can the overheating issue, good luck.
May 13, 2010 | HP Compaq Presario F500 F700 and G6000...
Have a HP f500 motherboard is dead. HP wont fix it, said was out of warranty, noone notified me at all regarding the issue (and I had to register the product before even using, providing them with current...
It's been a while since you posted this problem, still I hope this helps
You will need:
-presario F500 service manual (google it, you'll find it easily)
-a penny
Apr 21, 2010 | HP Compaq Presario F500 F700 and G6000...
My GE Advantium sca2000bbb03 does dont heat everything works right but wont heat.
I had this same problem with no heat. I called the GE rep out and he replaced the magnetron thinking that was the problem and put back together and had the same problem. I just happened to press in on the door while he was studying his diagnostics and it started heating. He then replaced the door switch and all was well.
Aug 22, 2009 | GE Advantium SCA1001SS Convection /...
I need to know if I put it back together right
If you pulled it apart and put it back together but now it won't work properly, try checking your IDE cables to the hard drive/cd-rom, make sure they aren't connected backwards. Otherwise just carefully look over the entire board, be sure that the processor, heat sink and fan assembly are all intact and connected properly, do the same with the RAM, power connection, any expansion cards.
May 06, 2009 | Computers & Internet
Draive wont take discs
Hi Spooks,
When you put the Disc drive back together, the mechanism probably did not go togther properly. You have to put it together with a disc in the drive. It is very hard to get the disc player to go back together properly I know. I needed three hands to do it. I done one. It took me several tries, but I finally got it. Another thing, since you have already disassembled your PS3 and need to do it again, go to Radio shack and get some Thermal heat transfer compound, Replace the compound between the heat sinks and processors. The original compound dries up after about a year and will kill your PS3 completely if you do not do this. Good luck,I know its not going to be easy.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
Rival CF300 Deep Fryer Logo
98 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
