Question about Frigidaire Washing Machines
Water is leaking, not from the hoses going in so I want to see if there is a leak inside. This is a frigidaire crown series top loader and I would like to take the sides apart, to look for a leak inside. I don't know exactly how. Thanks
  • eric bosman
    eric bosman May 11, 2010
    give me the model number and i can provide you most likely with a drawing
  • 3 Answers
Pls check the bearing assy
Posted on Nov 29, 2008
My 1998 Crown Victoria had steamed the passenger side windshield, digital thermostat never indicated that the engine was hot, i smell antifreeze, water leaking inside passenger side by glove box and a
It sure sounds like the heater core, especially if you have water leaking inside the cabin. The two heater hoses only go from the engine to the firewall, and do not go into or through the firewall. They connect to the heater core right at the firewall.
Check carefully around the back side of the engine and the heater hoses, though. If a freeze plug is leaking, water will be dripping off the bottom of the engine. If it is leaking before the firewall, that would not be the heater core.
Nov 20, 2013 | 1998 Ford Crown Victoria
Water leaking from the water filter inside top right of fridge when getting water on side by side fridgidaire gallery series. How do I correct?
If the filter itself is leaking then you will need to replace the filter, otherwise check the o-rings and lines going to the filter.
Sep 25, 2011 | Frigidaire GLHS38EES Stainless Steel Side...
Kenmore70 series washer 110.26752502 leaks water while filling
If you have a leak on a TOP LOADER, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect a TOP LOADER for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. The choice is yours if you wish to pursue this repair on your own. In my opinion, you don't need a "certified repairman" to find the source of a leak in most cases. Many of these repairs are simple with a little guidance. I hope this help you.
Feb 11, 2010 | Kenmore 22422 Top Load Washer
Noticed that our frigidaire crown series front loader washer has been leaking while wash cycle is going. Leaks occur at two places: from the bottom side of the door and also from the detergent dispenser...
Well from what ive seen the detergent dispenser will usually leak due to an excess build-up of fabric softener. If you remove the drawer and look up at the top of the dispenser you will see numerous small holes. If you see moldy gunk its fabric softener residue. This usually restricts the water coming into the dispenser causing it to "shoot out" in random directions. To correct the problem you can take a putty knife and scrape off the visible build-up then take a piece of wire or a pipe cleaner and stick it into the individual holes and clear them out one by one.
If you feel confident you could go as far as removing the top panel and the will be one access screw from the front panel that you can see and the dispenser can be removed. Be sure to disconnect the hose that hooks into it (it can be hard to remove and put back on) but then you could actually rinse it out, which is what I usually do.
If your leaking from the bottom side of the door its usually the way the water drips down from the dispenser or just a few drops of water from opening the door. Its common to see a water residue streak at 6 o'clock right under the door.
Hope this helps _MJ_
Feb 07, 2010 | Frigidaire FTF530FS Front Load Washer
Water is leaking from top loading frigidaire crown washer
go on line find model number on the back of washer
you should be able to fine seal kit and yes a new seal kit well do the job you well have to remove the drum unclamp hoses and remove you may want to have repairman come do this.
Nov 25, 2009 | Washing Machines
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Washing Machines Logo
207 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
