Question about IBM 05K9567 14.1 in. Flat Panel LCD Monitor
Blank screen i have a thinkpad notebook and when i turn it on, the screen is blank.. the power light is lit, but the monitor remains blank. i have tryed hooking up a desktop monitor to my thinkpad but it does not work either. i am not sure if i need to do something else to the thinkpad so that i can view on a different monitor. please advise. the desktop monitor works fine with my dell computer. i hear a noise at start up, but i am not sure if it is a beep. i have tryed the the buttons fn and fn & f7 as suggested by manual, but nothing happens. does this problem mean i need a new monitor or could it something else.
  • Anonymous Nov 25, 2008
    blank screen
  • 624 Answers
SOURCE: IBM Thinkpad (laptop) Monitor Burntout
It could be your LCD backlight giving you problems. With the computer on and the shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the laptop this is usually an economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Posted on Mar 20, 2007
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
  • 11 Answers
SOURCE: Blank Screen
ccfl ( cold cathode flouroscent lamp ) is the backlit feature of the lcd panel. If you see a blank screen but do see the output on the external monitor then you sure have to take it to the hardware tech to get the inbuilt LCD panel checked. it seems to be a electronic failure. Thanks Ashish.
Posted on Sep 22, 2007
SOURCE: notebook labtop screen blank
Something very simple....have you tried fnc+F7 (maybe F5) to change from monitor to lcd screen?
Posted on Nov 04, 2007
budmrtn
  • 11361 Answers
SOURCE: IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Feb 11, 2010
Testimonial: "thanks Bud, I'll see and then I tell you about. Best Regards...."
My Thinkpad does not seem to be powering on even after charging it all night. I have removed the battery, unplugged it, but still the screen is blank. The 2 houses that usually stay lit up after I turn on...
try to drain the battery. take out the battery and unplug the adapter. press and hold the power button and count 1 to 10. release hold after 10 secs. do it for 3 times. after that, put battery and adapter back in and monitor.
Mar 21, 2010 | Lenovo ThinkPad T400 - Intel Centrino 2...
The computer will start up but the screen will be blank
Try plugging in a regular computer monitor, if that works then you will need to open it up and check the screen's connection. if you get now lights from the regular monitor then you will need to check you ram/memory to see if it is connected properly.
Feb 27, 2010 | HP Pavilion dv9000z Notebook
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
SCREEN BLANKS WITH POWER LIT GREEN
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor will remain black when notebook is powered up
Black uses much less power. It's a device for automation, so you really should not lavish the watts and attention on it unless it has to perform something truly novel.
If you really want to use the monitor though, you can use the function-key combination used to switch the display between internal and external displays.
Feb 22, 2008 | Acer TravelMate 529ATX Notebook
Blank Screen
Sep 21, 2007 | IBM 11P836402 for ThinkPad R40 Monitor
IBM 05K9567 14.1 in. Flat Panel LCD Monitor Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
