Refrigerators Logo
Gary Leatham Posted on Jun 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Admiral ltf2112arw. Freezer fan icing, hitting blades and refrigerator not cooling well
6 yr old unit. After a defrost ice builds up quickly inside of freezer fan area so blade hit it and make a racket. Freezer very coid, but refrigerator section warming to 55 F. Is this a defrost timer, defrost heater or defrost thermastat? How to tell difference, or would you replace them all?
Jason Kennidy
Level 3:
  • Maytag Master 1,344 Answers
  • Posted on Jun 06, 2012
Jason Kennidy
Maytag Master
Level 3:
Answers
1344
Questions
0
Helped
370212
Points
4021
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
5 Related Answers
rpbuice
Ron Buice
  • 161 Answers
  • Posted on Dec 16, 2008
SOURCE: ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Apr 26, 2009
SOURCE: Fridge not cooling and Ice build up in freezer
It sounds like that when you noticed the fan was not working the refrigerator was also in defrost mode. This is not saying that the defrost position that you happened to catch it in was a normal function. If the defrost element was not on during defrost this will not allow the ice buildup to melt away and clear the evaporator for a fresh clear flow of cold air during normal running time. Also if the defrost thermostat is bad it will not allow the defrost element to come on during the defrost cycle. In short one of all four items could be the problem. Let me know, Sea Breeze
Anonymous
  • 18 Answers
  • Posted on May 29, 2009
SOURCE: Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
Anonymous
  • Posted on Jun 12, 2009
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Anonymous
  • 1606 Answers
  • Posted on Nov 04, 2009
SOURCE: 15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Candy CSC 1745WE fridge freezer just started making a noise like the cooling fan is catching on something.This noise stops when you put pressure on fridge or freezer doors. Any ideas, many thanks.
If the defrost is not working then ice could be forming inside the unit. If that's the case then it will get worse as more ice forms and the unit eventually wont cool or will cool very little. Sometimes a panel or the fan blade isn't adjusted right and it hits something making noises. In the case you would have to pull the covers off inside the freezer .
My Admiral mullion is hot
Probably the defrost element has failed, ice & frost will continue to build up & it's ability to cool will deminish over time. Has to be checked & possibly replaced.
2helpful
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
6 yr old Maytag getting warm
This could be the result of your refrigerator not defrosting properly. Look inside the freezer at the rear wall and see ice a layer of ice or frost is building. If the answer is yes then this would indicate a problem causing the refrigerator not to defrost. Hopefully it is only the=> 67002493 Defrost Heater Assembly
Instructions on how to test the defrost heater are found on the same page as the 67002493 Defrost Heater Assembly
Then there is also the possibility that the=> W10165425 Defrost Thermostat
If after testing these parts you don't find the problem then the problem will go to the defrost control found inside the fresh food compartment and behind the control panel=> W10207861 User Control and Display Board. I hope the problem is one of the two first parts I mentioned because the W10207861 User Control and Display Board
is expensive. I will be here to answer any questions you may have and assist you in you as you repair your refrigerator, Thanks Sea Breeze
Fan housing has frost buildup and fan blade is hitting the ice. I removed the ice about 6 weeks ago and it's doing it again?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator Fan Noise
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2helpful
2answers
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Whirlpool ET1FTKXK Fridge not working
The reason you had water dripping from the top is the frig goes into a defrost cycle every 12 hours or so and melts the ice build up. Now your drain line for the water to go down to bottom of frig is plugged more then likely with ice. Take the cover off back of freezer and get some salt table salt be good. And put it in the drain hole located roughly in the center of freezer cabinet. That will take care of the drain quick. Now notice to see if the fan on the inside of freezer is on. My hunch is that it is not turning. You can replace the little fan motor make sure you don't damage the fan blades you will re-use them. Be sure compressor is on cause the fan only works when compressor is on. Let me know what you find out.
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
My refegiator wont stay cold ,but my freezer gets cold my cooler grill gets like over iced and blocks the coolair from entering my refegiator .what to do. signed the admiral
Hi, for the meantime the admiral repair man not yet arrive you just defrost so that the ice will melted the cooling fan was shut off due to ice build up.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
