Question about KitchenAid KT2651X Epicurean Stand Mixer
Power On Problem
I have a KitchenAid 475 Watts KT2651XAC standing mixer. It has not been in use for a few years as it has been sitting in my Mom's basement idle. I took it out of the basement and wanted to use it. It seems to be practically brand new. When I plug it in it will not turn on. I have heard KitchenAid mixers have a "switch" or something which needs to be checked before it can be turned on again. Please help me. Thanks!
If you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Posted on Feb 09, 2009
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
I just purchase an Ultra Power Plus KitchenAid mixer ( 325 Watts). This is a sturdy and capable but there are two major drawbacks in comparison to my old Sunbeam Mixmaster. 1. The Sunbeam had two bowls --...
Wow. We at kitchenaid designed the unit for durability and very long life. The design brief was to build the sherman tank that whisks. You got it. A spare bowl may be purchased from your local supplier. Roller system ... no. It was considered but left the mixer "slippery ' On the bench so was discarded. Sorry. Happy mixing well into the future. See you for a service in 20 years.
Sep 18, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid 300 Watts KSM90 Ultra Power sparking
Sparking is a safety concern and Kitchenaid will see it as such. I would suggest calling Kitchenaid Customer Service. They are likely to exchange the product, regardless of warranty or age, because of the potential safety concern.
Their toll-free telephone number is 1-800-541-6390.
May 31, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid pro stand mixer will not turn on I has been sitting for 3 months without being used. It is a 475 watt bowl lift 6 qt mixer. about 3 years old.
How comfortable are you with electrical parts? With the mixer UNPLUGGED and the switch ON measure resistance between the (flat) plug pins. If it's infinite (no meter movement) which is to be expected, there is an open circuit. The switch could be open or the wire to the switch could be disconnected (improbable) or the motor could be burned out and open (not very probable).
Maybe you could take the switch to a shop and have it tested.
This is not really a solution, just step 1.
Feb 27, 2009 | KitchenAid K45SS Classic Stand Mixer
Power On Problem
Check to see if the contact points on the control board are working. Adjust the screws at the top of the control board until the contacts make contact. That should fix your problem.
Feb 13, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
No Problem
This is "middle of the line" Kitchenaid as far as bowl size and motor strength goes. However, it is a great mixer that will probably fit your needs.
Nov 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KT2651X Epicurean Stand Mixer Logo
329 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
