Question about Kitchen Ranges
I have a Primus 2255 camp stove. It requires screw in butane cylinder which I do not have. Are they compatible with other screw in cylinders? Where can I get one?
Most screw in butane cylinders use the same thread best bet is to go to a good local outdoor shop and ask them or try one at the shop
Posted on Sep 30, 2009
What type fuel and oil does this take
My searches of the internet indicate that this appliance is a multi-fuel appliance.
It is supplied with a gas bottle - for use with butane fuel
(see http://www.dx.com/p/campsor-9-split-type-camping-oil-gas-fuel-stove-silver-red-126914#.U0we9nlOVjo )
Read the reviews on that webpage for reviwers experiences with different types of fuel. Diesel doesn't work, it seems, but kerosenr and unleaded gasoline (petrol) work ok. You may need different connector for gaseous fuel and liquid fuels.
Coleman Naptha fuel apparently works well.
I hope this information is some use.
14.April.2014
Apr 14, 2014 | Universal CAMPSOR-10 Split Type Camping...
Do all stoves require priming?
No, priming is required for liquid-fuel stoves only. Its purpose is to preheat and vaporize a small quantity of fuel to ensure proper stove ignition.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
For camping with large groups, what is the recommended stove?
The recommended stove for large group camping I advise you to purchase the liquid-fuel stove.
My 12736 has a propane regulator. My old bbq had a butane one and a nearly full butane cylinder. Can I switch regulators?
Of course, you can change. Regulator to stabilize gas flow.
All gas BBQ product can suitable for both propane and butane
Jul 19, 2012 | Landmann 12376 Gas Grill
Can I use butane in a propane camping stove?
No. You should only use propane, as directed, in a propane camping stove.
Jul 09, 2012 | Camping, Backpacking & Hiking
Clogged regulator?
Disconnect the disposable bottle and make sure the stove's gas adapter is not clogged with insect debris or something. Also make sure your bottle is not empty by trying another one just in case! Douglas
Jul 10, 2010 | Coleman Grill
We have an old gas barbeque from B and Q which has been running of Butane for the last two years. We recently got a camping cooker which runs of either Butane or Propane. We need to buy a new gas cylinder...
I have worked on gas products for many years and have converted many from lp to natural gas and from natural gas to lp. What you want to do i would never try.
Jun 29, 2009 | Grilling
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Jun 26, 2008 | Grilling
Kitchen Ranges Logo
278 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
