Question about RIM BlackBerry Pearl 8100
I nedd the unlock code for at&t blackberry pearl
5 Suggested Answers
SOURCE: need unlock code for 02 blackberry pear 8100
ROLLERBALL WILL NOT SCROLL DOWNWARD
Posted on Jun 27, 2008
SOURCE: free unlock of blackberry pearl 8100
Option # 3: T-Mobile or Cingular, your carrier
Yes, you can ask your carrier for an unlock code for your Blackberry and guess what, they do it for it Absolutely FREE. So, what is the catch? The only condition which atleast T-Mobile imposes on its customers before it gives out the unlock codes for the Blackberry Pearl or any other cell phone is that you have to be under the contract for atleast 90 days or 3 months before they can give you the unlock code. So, if you have the patience, I would recommend that you wait for this 3 month time frame before calling up 611 from your T-Mobile phone, talk to customer service and get your unlock codes.
In my search for the Blackberry Unlock codes, I found out that a lot of people mess up before they have no idea how to enter the unlock codes correctly. So, follow this method to enter your Blackberry Unlock code
How To Enter the Unlock Codes on a BlackBerry Cell Phone
422851199_3d16b31e6c_o.pngModel : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
Posted on Jul 14, 2008
SOURCE: unlocking code for blackberry pearl 8100
you have to call t-mobile
Posted on Sep 24, 2008
label_chick
  • 407 Answers
SOURCE: blackberry pearl
Try holding these keys simultaneoulsy.
ALT+RIGHT SHIFT(CAP)+DELETE Until you get a blank screen then power on.
Failing that power off, remove your battery for 30 seconds and then power on.
Posted on Jun 02, 2009
  • 29 Answers
SOURCE: hoe to unlock Blackberry pearl 8100
It's a clear and fully detailed guide on how to unlock a BlackBerry pearl 81XX :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Posted on Jan 31, 2011
I need codes to unlock a blackberry pearl mobile phone locked to O2*
you can Unlock your Blackberry pearl with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry pearl. get your Blackberry pearl Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Dec 17, 2011 | RIM BlackBerry Pearl 8100 Smartphone
Tip
How to unlock blackberry phones for free?
Generally speaking this is not possible online, but save for a few Blackberry Unlock Code Retailers that provide this service for free.
One of these aforementioned services is Trusted Unlock. Currently Trusted Unlock is providing this service as a promotional offer which is currently valid..
The process is quite simple and is explained in further detail at their website located at Free Blackberry Online unlock.
Following models (and more) are supported:
  • Unlock Blackberry curve 8520
  • Unlock Blackberry Bold 9000
  • Unlock Blackberry Pearl 3g 9100-9105
  • Unlock Blackberry Curve 3g 9300
  • Unlock Blackberry Bold 9700
  • Unlock Blackberry Bold 9780
  • Unlock Blackberry Torch 9800
  • Unlock Blackberry 8100 Pearl
  • Unlock Blackberry 8110
  • Unlock Blackberry 8110 Pearl
  • Unlock Blackberry 8120
  • Unlock Blackberry 8120 Pearl
  • Unlock Blackberry 8130
  • Unlock Blackberry 8220
  • Unlock Blackberry 8220 Pearl Flip
  • Unlock Blackberry 8300
  • Unlock Blackberry 8300 Curve
  • Unlock Blackberry 8310
  • Unlock Blackberry 8310 Curve
  • Unlock Blackberry 8310v
  • Unlock Blackberry 8320
  • Unlock Blackberry 8320 Curve
  • Unlock Blackberry 8330
  • Unlock Blackberry 8350i
  • Unlock Blackberry 8500
  • Unlock Blackberry 8500 CURVE
  • Unlock Blackberry 8520
  • Unlock Blackberry 8520 Curve
  • Unlock Blackberry 8520 Gemini
  • Unlock Blackberry 8700
  • Unlock Blackberry 8700c
  • Unlock Blackberry 8700f
  • Unlock Blackberry 8700g
  • Unlock Blackberry 8700i
  • Unlock Blackberry 8700r
  • Unlock Blackberry 8700v
  • Unlock Blackberry 8703e
  • Unlock Blackberry 8705
  • Unlock Blackberry 8705g
  • Unlock Blackberry 8707g
  • Unlock Blackberry 8707v
  • Unlock Blackberry 8800
  • Unlock Blackberry 8801
  • Unlock Blackberry 8810
  • Unlock Blackberry 8820
  • Unlock Blackberry 8830
  • Unlock Blackberry 8900 Curve
  • Unlock Blackberry 8900 JAVELIN
  • Unlock Blackberry 9000
  • Unlock Blackberry 9000 Bold
  • Unlock Blackberry 9020
  • Unlock Blackberry 9100
  • Unlock Blackberry 9100 PEARL
  • Unlock Blackberry 9500 Storm
  • Unlock Blackberry 9520
  • Unlock Blackberry 9520 STORM 2
  • Unlock Blackberry 9525
  • Unlock Blackberry 9530 Storm
  • Unlock Blackberry 9550
  • Unlock Blackberry 9600
  • Unlock Blackberry 9630
  • Unlock Blackberry 9630 NIAGARA
  • Unlock Blackberry 9700
  • Unlock Blackberry 9800 Torch
  • Unlock Blackberry 9900
  • Unlock Blackberry Gemini
  • Unlock Blackberry Niagara
  • Unlock Blackberry ODIN
  • Unlock Blackberry ONYX
  • Unlock Blackberry Pearl 3G
  • Unlock Blackberry RIM 850
  • Unlock Blackberry RIM 857
  • Unlock Blackberry THUNDER
  • Unlock Blackberry TOUR
on Oct 12, 2010 | Cell Phones
Sir pls give blackberry pearl 8100 unlock software
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your BlackBerry pearl 8100.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Jun 15, 2011 | RIM BlackBerry Pearl 8100
Unlock blackberry pearl 8100 Model: Blackberry pearl 8100 Pin: 25160503 Imei: 356920018929637
you can unlock your Blackberry PEARL 8100 eaisly with Blackberry Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry Unlocking Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
May 20, 2011 | RIM BlackBerry Pearl 8100
I have a locked Blackberry 8220 pearl flip, locked for Rogers wireless in Canada. Does any one have the MEP code to unlock it? The IMP number is 356028025545378. Please email me back at . Thanks Aaron
Don't worry about it. it is very simple to Unlock your Blackberry 8220 Pearl Flip by entering Imei Unlock Code . you can get your Mep Unlock Code for Blackberry 8220 Pearl Flip by third party or your network provider.third party give your Imei Unlock Code within hour. but your network provider take time to give you Imei Unlock Code. and charge huge amount. you can buy Blackberry Imei Unlock Code from third party. they will charge little amount.i hope this will help you.
Aug 11, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I want to unlock my 8220 blackberry
Here are the updated instructions to unlock the RIM Blackberry Pearl 8220 (Flip):
Read more: http://www.mobileslate.com/blog/2008/11/04/how-to-unlock-blackberry-pearl-8220-flip/#ixzz0fNwiPynn
hope this helps! have a great weekend!
Feb 13, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I have a blackberry pearl and want to unlock it instantly for free. is this possible?
Research In Motion does not have the Carrier Unlock Code to unlock BlackBerry devices for use with other carriers. To obtain the Carrier Unlock Code, contact the service provider from which the BlackBerry device was originally purchased.
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
I nedd the mep number for my blackberry
both are safe way to Unlock your Blackberry Pearl 8100.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Jul 05, 2009 | RIM BlackBerry Pearl 8100
How to unlock black barry pearl 8220 flip it is imported from canada to india
you can Unlock your Blackberry pearl 8220 with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Blackberry pearl 8220 Imei Unlock Code . and use any gsm sim card.
Jun 13, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry  Pearl  8100 Logo
27 people viewed this question
Top RIM Computers & Internet Experts
Trisha
Trisha
Nataly Roberts
Nataly Roberts
asber
asber
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
