Question about Everex StepNote NC1500 Notebook
My laptop can not be started or run can not open windows. only black screen and some fun noise i don know what is wrong. please assist me.
  • CForce Dec 13, 2008
    My laptop sounds like it is running at startup, but I only have a black screen. Nothing shows up on the screen. Any help would be appreciated.
  • Richard Lilja
    Richard Lilja May 11, 2010
    We need to know what text shows up on the screen before further help can be given!
All of a sudden I lost my Desktop Wallpaper which was originally had with this laptop
Go to Start > Control Panel > Appearance and Personalization > Personalization. This is where you customize. The variations are endless. Have fun.
Oct 03, 2012 | Sony VAIO Computers & Internet
My asus eee pc 1005hab screen is not displaying anything, even at start up. the screen is just black yet the fun is running. this is after a friend of mine used cmd to try formating his flashdisk. probably...
turn on your computer, press F2 button. if it can log into the bios setup it means you just have a software issue. Reinstalling the window will do the magic. if your netbook didn't display anything from the time you turn on the netbook, it means something wrong with your hardware.
Jun 13, 2012 | ASUS Eee PC 1000HE Netbook
Screen not displaying. and fun starts and stops, remains stand by when restarted the fun runs and stops stand by.
hello there,
I got the same problem but it came gradually...
In fact for a full month when I first boot the computer, the fans runs, no extra beeps, the light blinked correctly but no bios at the screeen. I remarked also that the fans run full speed doing a lot of noise. Then I stopped the computer and wait 2 minutes and then it always works correclty at the second boot with the bios screen appearing. Also, the fan calm down after 1 second with less noise. So when I start the computer and hear that the fan calm down with less noise after 1 second, I know that the computer will boot correctly. That happens always at the second try after waiting 2 minutes. But since yesterday, the fans never calm down and the noise still remains high with no Bios at the screen. I'm suspecting the Power Supply...
i hope my i dea can help you.
Sep 02, 2011 | Dell Inspiron 1545 Notebook
When I turn my laptop on the desk top with the start button and other icons together with material I have saved on my desk top are not shown. The screen is blank and black
reboot it in safe mode and if it shows desktop restart once again
booting in safemode hold F8 while restarting your machine choose start window in safe mode and hit enter
best of luck
if problem wont solve let me know please i will tell you another way
Aug 19, 2011 | Computers & Internet
I turn it on and i hear it booting up by the screen remains black
Hey there, if the screen remains black during the entire thing (not even the bios or any text showing up while booting). I'm sorry to tell you but if that's the case then this is not something you can fix by yourself. I recommend going to your local PC store and having them look at what exactly is wrong.
PLEASE NOTE that you should ask them to first only look at what is wrong. If the screen needs to be replaced, it can cost nearly as much as the laptop itself and you may want to consider just buying a new laptop instead. However this is the worst case scenario, chances are also that the connection with the screen kinda loosened up by opening and closing your laptop too much, in which case it should be pretty cheap to fix it. Of course if you still have warrenty on your laptop that would be great.
Another thing you can do, which i DO NOT RECOMMEND AT ALL unless you have experience opening up laptops, is looking at it yourself, and checking if the connection is loose. Or if you come to the conclusion that your screen is broken then you could buy a new one for about 200 dollars (this was the price for my laptop's screen anyway) and putting it in yourself, but once again sorry to repeat but this is highly not recommended if you don't have experience, if you do decide to do this please do proper research on which screen you should buy etc.
I hope I was able to assist. If I was, please don't forget to rate my solution.
Jul 27, 2011 | Dell Inspiron 1501 Notebook
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
My hp pavilion dv6-3052nr laptop has windows 7 64 bit installed.and i installed Nero9.after installing Nero9, the second time i couldn't open windows.when i switch on my latop, black screen glows and...
Try to boot into safe mode (if you dont know how do to this, do a quick google search). If you can get into safe mode go to start and type system restore in the search box. Run a system restore to a time prior to installing nero and give it another try.
Mar 12, 2011 | Computers & Internet
Stuck CD/DVD tray on HP Pavilion laptop
hi ther
how r u ??
u just do it manuly but not by the button
in teh tine hole poke it with a paper clip try it untile u get resistance and push
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | HP Pavilion DV5234US Notebook Laptop
Screen black
Are any USB device connected to it? If so, disconnect them.
Try to start now, if this does not work:
When the system boots up, try hitting the F8 Key and see if you get a Windows menu? If so, try and start in Safe Mode. If this works, you have a hardware failure and you will not need to look for the problem. First place to start is reboot and F8 again and this time go in VGA mode. If this works, Run Windows update and this should replace any drivers that are not good, including video. If you cannot get in VGA mode, you know your problem, the video adapter or drivers. Remove them in Safe mode and run Windows Update.
If you need any additional assistance just click "ASL ME"
Please remember to rate this solution
Sep 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Everex StepNote NC1500 Notebook Logo
Top Everex Computers & Internet Experts
k24674
Alun Cox
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
