Question about Kenmore Washing Machines
All setting are only washing via 1 cycle
Since I changed the water hoses, my Kenmore mod 100 70 Series is only wasing the clothes with 1 cycle.
    Genius:
  • 1,028 Answers
Be sure both faucets are full on and hooked correctly most washers have only cold rinses
Posted on Nov 29, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
Washing Machines Logo
Sal De GO PATS
fordexpert
Ed Mac
