Question about ASUS LCD Monitor
LcD say "video Out of range
Was changing resolution and the screen said video cannot show in this mode
    Champion:
  • 293 Answers
Hey...
It's mean your monitor not support to this ranges... need to reduced the resolution to mfg. settings...
Posted on Nov 29, 2008
I have a message on my monitor that says, Out of Range. What can I do about it?
you need to change your screen resolution. the best way would be to hook it up to a bigger monitor or a television- one that can handle the present screen resolution, and then back the resolution down before re-hooking up the 19" monitor.
or you could boot in safe mode, uninstall the video driver, and then reinstall the driver, to reset the screen resolution to a basic resolution.
to change your screen resolution (hooked up to a different monitor) right click on the desktop and select "properties" in xp or "personalization>screen resolution" in vista/7.
Oct 28, 2010 | Envision 19" Widescreen Flat Panel LCD...
Input signal out of range......my problem...hp w1707
your video card setting may not be compatible with your monitor's capability. you may need to reduce the screen resolution. you need to boot up on safe mode to change this or use another monitor for a while and try to adjust the screen resolution.
Oct 07, 2010 | HP W1707 LCD Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
My screen is showing message "Not optimum Mode, Recomended Mode : 1024 x 768 60Mhz. ?
you need to change your video adapter resolution to this one,if you can`t see nothing in normal moe login in safe mode(tap f8 on boot)and change resolution then restart
Jun 13, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
Monitor shows out of range when not in safe mode
Mine displayed out of range when i tried to go too high with the screen resolution. Totally flipping out like an untuned tv. Display properties of 1280x800 work best for me... though i wish i could go bigger without weird stretching of the view
Jul 24, 2008 | X2Gen MG19MY 19" LCD Monitor
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
ASUS LCD Monitor Logo
311 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
