Question about Nikon COOLPIX L18 Digital Camera
Error message: file contains no image data
I can see the picture on the screen and then it immediately goes away and i get the error msg above. It does this about every 4th or 5th picture I take. I can still review the picture and it immediately disappears and gives you the above message.
  • 7 more comments
  • choz Dec 14, 2008
    I have the sam problem and if I tranfer the pics to my computer, it's not able to open it
  • PunkRockRae Jan 02, 2009
    I have exactly the same problem and looking for the same answer!
  • rozes14 Jan 05, 2009
    and how do you fix this problem?
  • calilove92 Feb 12, 2009
    I have the exact same problem and so does my mother in law she has the same camera. How do we fix it?
  • Anonymous Feb 13, 2009
    i had the same problem then i formatted the card and problem solved.
  • grayss Apr 02, 2009
    when viewing or downloading pix image shows, but is immediately replaced by "error message: file contains no image data". Those already downloaded show up on the thumprint, but when I try to open them, the message reads "drawing failed".
  • hemiklr09 Apr 20, 2009
    my card is brnad new... took about three photos, shut it off. turned it on too take some more, and started to get the massage above.. is it the memory cad?
  • arnab_cha872
    arnab_cha872 Jan 22, 2013
    thanx for solu
  • Anonymous Feb 14, 2014
    check out this guidehttp://www.asoftech.com/articles/file-do...
Hello!
I may be able to add some advice on how to solve this unfortunate problem of "file contains no image data". I have been suffering from the same problem. I have recently been on some amazing vacations and the photos I have lost due to this problem have been invaluable to me! I would pay an insane amount of money to get these photos back, but unfortunately I cannot!
I have a nikon coolpix camera. I contacted the nikon coolpix technical support center. I spoke with a representative who asked me what type of memory card I have. As it turns out I have a generic memory card, which is not compatable with nikon. The only memory cards brands that are indicated to be used with the nikon coolpix camera that I have are as follows: Toshiba, Panasonic, Lexmark, and Sandisk. Those are the only 4!
I was told that if you use another memory card besides the memory cards brands that I have listed... that the camera may communicate incorrectly with your memory card, which results in data that is incomplete to support an image. When this happens you will only see a portion of your image, and you cannot get it back. These bad images with incomplete saved information are called "corrupt files". The representative told me that there are some programs that are available to purchase that may be able to correct corrupt .jpg files, but she believes that they are memory card brand specific.
To put it simply, when you do not have to compatable memory card in your camera, it is as if your camera is speaking english and your memory card is speaking chinese and they are not communicating properly (this was the way the representative explained this problem to me). So check your user manual for your specific type of camera or look it up online to see what type or brand of memory card you should be using! I truly hope this helps someone avoid losing invaluable photos!
Posted on Aug 16, 2009
  • Rob Mason
    Rob Mason Jan 12, 2014
    Your post was very helpful changed to a Scandisk took care of it
I just went to a local photography store and asked about it and found out that it happened because I was turning off my camera before it was finished saving the picture. I looked through all of my pictures and realized that every picture that would start to load and then say "File contains no image data" was the last picture in a series of pictures before turning off my camera.
So basically, you need to wait until the little light stops flashing and it has finished saving all of the data.
(Another way I found out about this problem was when I loaded them onto my computer, these pictures had gray bars at the bottom.)
Posted on Mar 21, 2009
I have identified the main issue as to why we see this error message: file contains no image data. Don't worry there is nothing wrong with your memory cards. They are working fine and are not corrupt. Yes, they are not corrupt. I repeat.
The issue occurs when you rotate the image either on the camera or your computer and then try to view the saved images on your camera again. During this testing I did not loose any images on my card. All images still display on the computer when I insert the card in the computer. It's just that I am not able to view them on the camera. I believe it is just a bug in the Nikon Coolpix cameras.
Posted on Mar 29, 2012
  • paswal01
    paswal01 Mar 29, 2012
  • 30 Answers
You have got a virus on your card, or maybe even on the main board. I have had Norton antivirus and it did not detect viruses on my camera or computer. Kaspersky detects well. Once you insert infected card into PC it tells you you've got a worm virus!
Posted on Dec 12, 2008
  • Rasheed Bashirov Jul 21, 2009
    Most of the electronics use electrolyte capacitors which life is 1000-2000 hours (0ne year?) and once they are dry and stop working you have all kind main board malfunctioning, including this type of switching off after taking 4-5 pictures, most likely because of higher currents due to lost capacitors. Replacing the main board from another damaged (as-is) camera from ebay also helps. When you buy a camera for the main board look for the one that has both LCD and lens damage with no accessories, scratched up, those sell for 3-6 bucks. When you buy such camera, all you care in the description that it powers up
I do have an approved memory card (ScanDisk), but the problem still occurred. Unlike some of the other posters, no pictures were lost. After seeing the "file contains no image data" error message, all the previous pictures could be viewed by just stepping backwards through the photos.
The problem came about when I used the memory card in another device (Kodak Zx3 video camera) and then transferred the memory card back to my Nikon CoolPix. My solution to the problem was to insert the memory card in my laptop and delete the folder (and thus movies/images) associated with the Kodak Zx3 video camera. After doing that and transferring the memory card back to my Nikon CoolPix, the error message no longer appeared.
To verify that using the memory card in another device really caused the problem, I used the memory card again in my Kodak Zx3 video camera, took a few movies, and then inserted it back into my Nikon CoolPix. Sure enough, the same error message appeared.
Moral of the story? Don't use your Nikon CoolPix memory card in different devices.
Posted on Jul 02, 2012
I found before a minute. I have same problem and I had to delete hundreds photo. I notice what is problem but I can not any solution yet. If you take photo and you rotate these photo in your pc, images programme name change. So, the camera do not accept another programme. I do not know how I fix it.
Posted on Feb 13, 2011
    New Friend:
I saw the same message when I used the card from my Canon in the Coolpix. Panic set in when I thought the Christmas photos were lost! Funny thing was, I could see those photos when I inserted the card into my computer, and the camera itself was willing to play all the pics (including the ones from my old camera!) when I put it in "slideshow mode." So I knew the camera was in fact recording and saving new photos. Using a new card (not one of the 4 listed) solved the problem of the error message. Marvin was right... the Coolpix does not like to share with other cameras (and it has a nasty lying streak!!)
Posted on Jan 22, 2013
My vw polo is shudering at 60kmp on 4th and 5th gear, i have changed the gearbox but the problem still haunts me, what can be causing it?
Could be an unbalanced wheel, could have lost a balancing weight from the rim. Could also be caused by a slipped belt inside one of the tires. To eliminate a tire issue swap front to rear tires, see if the issue goes away or moves to the back end.
Aug 08, 2014 | DURATRAX CV Drive Shaft Set Blu Alum Mini...
1990 honda civic looses power in 4th and 5th gear
sounds like misfire.
the CEL glow at this misfiring< yes, then pull the DTC errors.
know how yet?
#1 reason for misfire is, SKIPPING the 60k mile tune up. #1
#2 above done. is low fuel pressure.
there are many more, but we do tests to find them. ask
Dec 14, 2013 | Honda Civic Cars & Trucks
2010 crf450r jumping outta gear from 5th to 4th all other gears work fine
Terrence >>>> 1. Do not go through the gears while idling on a stand!!!
The rear tire is not moving at the speed that is normal for 4th or 5th gear..AND if you do get the tire moving that fast.. it is BEYOND DANGEROUS!!
This sounds like the 4th and 5th gears may need replacing.. or the shift drum detent for 5th gear has somehow become ineffective.. If you continue to ride this bike , you may cause more trouble and damage to the transmission.
Take this to a qualified professional!!
Jun 24, 2017 | Honda Garden
When purchased, upon starting the car, the radio (manufacture model) volume knob would actually be turning down when you were turning the radio knob up, and it did the opposite if turning the knob up, the...
sounds like a serious electrical issue there hard to track down could be the computer staarting to go in car the radio could of been hooked up wrong causeing other stuff to short out what year is the car what kind of car
Dec 01, 2010 | Pontiac Grand Prix Cars & Trucks
When i change up into 5th gear after about 30 seconds it pops back out of gear and i have to change into 4th because it wont go into 5th straight away.
it could be problem with 5th gear and shifter shaft, give it to workshop they will replace faulty gears.
Jan 29, 2010 | 1998 Kia Sportage
While cruising around 40 to 45 MPH steady in 4th or 5th gear
try to replace plugs maybe even wires depending how old...
Aug 16, 2009 | 1991 Toyota Pickup
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Trans noise growling metal...3rd,4th and 5th low speed
I'm not sure, but that sounds like the throw-out barings. If thats the case and they went before the clutch did, then their could be some big problems up ahead.
Jul 31, 2008 | 2000 Toyota MR2 Spyder
Nikon COOLPIX L18 Digital Camera Logo
7,818 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
