Question about Water Heaters
Small seepage underneath hotwater heater.
Not sure of hotwater heater's age, but suspect it could be15 years or so. It is an A O Smith, model FSG 50 232. Its Energy Guide label makes reference to 1994 guidelines. My question is whether the seepage is an indication I need a new tank?
  • Anonymous Mar 14, 2014
    NO HOTWATER
    Problem Solver:
  • 17 Answers
Soetimes its gaskets around flanges and heater element fixings that fail
have a good look round after drying the area with tissue etc.
leave a dry tissue round the based so you will see tell tale trace stains where its perhaps leaking from
Posted on Nov 29, 2008
Water heater blower has broken flywheel. Are replacements available? A.O.Smith FPSH 50 236 with Fasco blower 7102-10195
here is a link to look and see the part you need then ill help you find it.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0CCQQFjAA&url=http%3A%2F%2Fwww.hotwater.com%2Flit%2Fpartslists%2Fpsd1287.pdf&ei=0SzuUpGQO7fNsQT6jYLwDw&usg=AFQjCNGmLNSvxmXxCzZlYxXIHQlps9NgGA
Dec 23, 2013 | Rheem 81VP6S/430126 Water Heater
AO Smith BTH 500 ignitor keeps burning out,is my electronic control the problem?
I would report problem to AO Smith.
Also ask question on pro water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
If the igniter is not turning off, then that would explain early failure, and it would be caused by the control chipset
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 21, 2013 | A.O. Smith BTH-500A BTH-500A 130 Gallon...
On A.O. Smith water heater model BTH 199 100 where is the heat sensor rod located ?
Parts list:
http://www.hotwater.com/lit/partslists/197728-004.pdf
Flame rod, flame sensor sits next to igniter inside combustion chamber. This can be cleaned with sandpaper. Do not touch with fingers. Purpose of flame rod is to detect whether ignition has caused actual, sustainable fire inside the combustion chamber.
If sensor is bad, or no ignition is detected after 2-3 attempts, then 'no ignition' error is given.
Bad gas control valve, bad-or-dirty flame rod-sensor, low gas pressure, misaligned rod, dirty combustion parts, etc
Service handbook:
http://www.hotwater.com/lit/training/316586.pdf
High gas pressure spikes can daMAGE gas control valve p7
Product manual:
http://www.hotwater.com/lit/im/com_gas/197727.pdf
Word-search for 'failure'
Low gas pressure. p14 and p54
1-3 trials before declaring 'ignition failure. p48
bad flame sensor (clean with sandpaper) #10 p58
unit must be grounded (check outlet with circuit analyzer) #12 p58
Sequence flow chart p59
Rough starts = ignition failure p60
Troubleshoot chart - ignition failure p62
Mar 12, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
To light the pilot on my OS Smith water heater, I follow the instructions in the label, but nothing happens, no hot water after one hour. Read that there is problems with water heaters, I have some...
Thank you for providing clear description of product:
Your water heater has intellivent gas control thermostat.
There are always problems with water heaters. It is a huge field.
1) Open following link for AO Smith service manuals.
I do not see service manual specifically for the GP series.
2) Open following link to identify gas valve and download typical service manual:
Some AO smith power vent models have intellivent gas valve, and some have smart valve gas vent. Older models might have knob-type gas valve.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 23, 2011 | Water Heaters
AO Smith Water heater FPSH50-260 keeps blowing fuses
FPSH series is a power vented residential gas water heater.
1) The blower is plugged into 120Volt outlet. If blower has short, then it will trip breaker.
Blower could be Fasco model 7021-10195, or 7021-10770. Call AO Smith: 1-800-527-1953. They will need model number and serial number located on label on side of tank.
2) Before calling AO Smith, check outlet with circuit analyzer. Outlet must have correct polarity and must be grounded. Unplug cord to water heater and run continuity test from ground prong on electrical plug to manifold tube on gas valve.
3) Also if a fluorescent light fixture is on the same breaker, that can cause burner to short cycle.
4) Connect water heater to different outlet and see if problem continues.
5) AO SmIth has service manuals for the FPSH series that download to your computer:
Sep 20, 2011 | Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a whirlpool water heater mod. Fg1f4034t3nv. Igniter will not work'.instructions missing. Have all lines. Etc disconected how do I get assembly out?
I don't know because I can't see it, and I don't have manual.
But I can give you resources:
Call Whirlpool:
(877) 817-6750
Whirlpool is usually Craftmaster which is American which is AO Smith.
http://www.hotwater.com/water-heaters/residential/conventional/gas/
Age of water heater shows on serial number: first two digits should be year, second two digits should be week.
The market is always changing.
Find manufacturer using label on side of tank, find manual with parts diagram, and order burner parts. Whirlppol site does not have manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
It might be cheaper to install a new water heater yourself from box store for $330.00
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 05, 2011 | Whirlpool Water Heaters
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
Water Heaters Logo
281 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
