Question about Philips DVP642 DVD Player
Getting DVD's to play in color
Can not get the dvd to play in color
Just had the same problem with mine. It would not play DVD's in color, but the TV's color was great. I put in a DVD and started playing it. I unpugged and replugged the S-video cord while the DVD player was playing a movie. This was an instant fix for mine. The color is back while watching DVD's. Hope this will work for you too!
Posted on Dec 02, 2008
4 Suggested Answers
  • 53 Answers
SOURCE: Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
Posted on May 03, 2008
shameerariff
  • 89 Answers
SOURCE: DVD disks just play in black and white. No color.
This is because of the audio video format issue. You select the TV type to auto (Advisable) or to the appropriate selection such as PAL or NTSC in the DVD player to get the better output with the color.
This selection you usually find in settings > Video setup> TV Type
Posted on Aug 06, 2009
SOURCE: my dvd player does not play in color only black
don´t you by mistake change the video format check that on the menu
Posted on Oct 06, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
Apr 06, 2010 | RCA Televison & Video
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
We have a Panasonic DVD-S35 wont play color
We have a Panasonic DVD-S35 wont play color UK dvd's, US dvd's are ok any idea what's wrong?
Dec 27, 2009 | Panasonic DVD-S35 DVD Player
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
DVD player car screen plays dvd in B/W , navigation in color
try checking the color system if its ntsc or pal
Jul 11, 2009 | Car Audio & Video
No longer plays color picture
Try the settings for "pal - ntsc - cvbs" video formats, if the tv and dvd aren't set the same, then this can cause the problem(usually with distortion to picture, depending on how it's mis-matched)
Jul 05, 2009 | Coby DVD-224 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Philips DVP642 DVD Player Logo
243 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
