Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool top loading washer Model # LSR8233EQ0 that the water mixing valve needs to be replaced. How do you get to that valve? Do you remove the back of the machine or go from the front?
    Sergeant:
    Champion:
  • 311 Answers
Do not remove the back.Take 2 screws off front ends of console and pull slightly forward and flip it up- it is hinged on the backPop off two spring clips that engage cabinet. Unplug lid switch wire. Tilt cabinet forward and the whole thing comes off. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Whirlpool Cabrio Platinum water is coming back out of the hot hose
You have a hot , cold and a mix valve ,I would suspect that the mix valve is stuck, try tapping on it
Whirlpool W10372095 Valve AppliancePartsPros com
May 26, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
We have to turn the water on from the wall to get the machine to work, then afterwards, we have to cut the water source off if not, it will keep running.
One of the solenoids in the fill mix valve is stuck open. The mix valve will have to be replaced.Its a fairly easy repair on a top load and the part is about fourty dollars.
Sep 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
Top Load Ultimate Care 2 Just below the lid in
This problem is commonly caused by a water inlet valve (also known as a mixing valve) leaking by. If you live in an area that has hard water, or if you use well water, sediment, rust or calcified deposits can accumulate in the inlet valve and cause it not to close properly. Usually when they start leaking, you need to replace them. The following link explains how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
If the model number is correct, the part number for a replacement valve is 285805.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
When control on warm or hot no warm or hot water comes out, just cold
The problem is a bad hot water solenoid on the water inlet valve (also known as a mixing valve). There is a separate solenoid for hot and cold water. If the hot water solenoid fails, you will not have any warm or hot water. Replacement is simple and inexpensive. The following link explains how to access and replace the inlet valve on a Kenmore top loading washer:
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service. Prices vary between them so shop and compare.
If you have any questions about this repair, or have need additional assistance, please post back with your complete model number (located along the wash tub rim under the washer lid). I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Dec 10, 2009 | Kenmore 22422 Top Load Washer
My Washer is only filling with hot water and cannot complete the rinse cycle because hot water is not an option.
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. Since nearly all washers use cold water only during the rinse cycles, you are correct, the washer will not complete a full cycle. You will need to replace the inlet valve. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Need to Know how to remove top and cabinet
first, do you have phillips screws on back of console at bottom goin down or in front bottom? one or the other remove these then slide console forward and fold back on hinge on top. if no screws then clips are hidden on front edge on end plates. use putty knife from front to push and release lifting console at same time. fold back.
use screw driver to pry and release brass clips holding top to rear panel. unplug lid sw connector and pull cabinet body away from machine. top and cabinet is screwed together and removed as one piece. cabinet hinges under base on front and sits on top of sides.
May 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Need to get into the water mixing valves on Whirlpool washer
with putty knife press in clips at each corner of console and lift up ..also press same type clips at front edge of top about 2-3 ins in from each corner
Nov 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSR8233EQ0 Hot water (only) trickles
you need to replace the hot cold inlet water valve on the back of washer,the solinard for the hot water is not opening all the way,this is a common problem on all washer,if you go to sears .com click on parts put in your model number you can get the part and it shows you where it goes,hope this helped you-mike
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
WHIRLPOOL TOP LOADER OVERFILLING WATER
While it is filling up try this. Unplug the washer from the wall, if the water still runs then you need to replace the mixing valve. If the water stops then take the screws out at the base of the console and flip the controls back. Look for the clear hose that goes to the water pressure switch and make sure that it is connected. If it is connected take it off the switch and blow through it to see that it is clear of any obstructions.
If this only overfills after the first ore second wash then you may have the slow drain and the drain hose is in the downspout too tight.
Possible items needed;
#1 mixing valve
#2 pressure switch
#3 plumber
Jan 20, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De
