Monitor is saying out of range - Computers & Internet
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    try starting in safe mode(F8 key repeatedly while starting the comp) and then change the display settings..
  • pklinuxguru
    pklinuxguru May 11, 2010
    I've seen this problem on servers connected via a video switch box when the monitor is not quite compatible with the server. (Especially a Sun connected to a PC VGA monitor.) Did you recently purchase a new (or used) monitor?
  • 136 Answers
Boot your PC in safe mode.
Uninstall your display driver.
Restrat your PC.
Reinstall your display driver.
Thats it.
Posted on Nov 29, 2008
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
ONE CAMERA SAYS OUT OF RANGE
Try to walk closer to your camera with your monitor to see if the video feed appears. If not, you may want to send your unit in for repair.
Jun 08, 2015 | Uniden UDR444 Video Survailance System;...
Monitor say out of range
Just connect the monitor to another computer and change the screen resolution to 1024 x 768 or less. This means that the computer that is connected to that monitor, can not display the mode that your monitor is in right now.
Feb 27, 2012 | Princeton Digital Computers & Internet
Monitor's resolution need to be increased, how?
Hi
You don't say which operating system you are using.
The monitor resolves images across a fixed range of resolutions and resfresh rates.
It is the resolution of the graphics card or graphics adapter that can be changed, not that of the monitor.
Right click on empty space on your desktop > properties > settings.
Left click and hold on the slider and slide to the right in stages.
Each resolution change offers you a test page to accept or reject.
When satisfied Apply > Yes > Ok.
To reset the Refresh Rate:
Properties > settings > Advanced > Refresh Rate.
Then restart your computer.
Be careful not to exceed the resolution/refresh rate range of your monitor (1280 x 1024) / 75.0 Hz because if you do, when you restart the computer, the monitor will be unable to resolve the image and you will get a blank screen and/or an Out Of Range error message.
An out of range problem might only be resolved by using a different monitor to reset the resolution back to within the range of the preferred monitor.
Hope this helps
Aug 22, 2011 | Northgate MONNG7NSS 17" Flat Panel LCD...
Had summer baby monitor for eight months, last night it stopped
Your monitor has become unpaired with your camera. Follow the instructions in the manual to pair them again (basically, tell the monitor piece to Add New Camera while you press the Pair button on the camera). The manuals can be downloaded from www.summerinfant.com.
Jul 08, 2010 | Summer Infant Day & Handheld Video...
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
Screen says out of range
I would say that the computer is trying to use a display resolution that the monitor is incapable of displaying. You may have to lower the resolution from the PC before you get a picture. Make sure you install the correct drivers for the monitor onto the new computer and use a different monitor to adjust the display resolution to a level that the monitor is capable of displaying.
Dec 15, 2009 | AOpen F2705 17" LCD Monitor
Soyo monitor: Out of Range
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
Aug 24, 2009 | Soyo Computers & Internet
Out of range
You can try removing signal cable from pc.If it still says "Out of range" most probably main logic card or interface board as it is known in the lcd monitor could be defective.If on the other hand removing the signal cable gives message No signal ,cable not connected,try connecting monitor to another working known pc.If it still doesn't work the interface board in the monitor is defective.
Feb 26, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
