Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
When i comin in the set up system it askme for a password
My child put a password for the family computer on the setup , but now he not remember the password
what i can do please help me
what a need to do for remove this password
  • 20 Answers
Another to reset the password .
If the password was entered for the Bios (that is, right when you turn the PC on and NOT loading Windows, You can reset the BIOS in the following way. It requires a little toolwork and inside the case work though it is an easy fix. This fix requires a little BIOS knowledge and someone familiar with the insides of a computer case though. Make sure the PC is completly OFF! (unplug or use switch on Power supply)
Open the case, by unscrewing or unsnapping the side of the case and get access to the inside of the PC. Ground yourself out to the PC by either connecting a piece of naked wire from your hand to the metal walls of the case or use a ground clip from your local PC store. Next, find the little round battery that looks like a watch battery and looking around you should see a jumper set on a 3 pin point. It should say on the Mother board "reset" or something like that. Move the jumper to the other exposed pin wait a few seconds and return it to its original position. If you have a Mobo manual it will show you exactly where on the board this jumper is located. you can also get this info from the boards website under manuals. Plug everything back in or switch on leaving the side off the case and turn on the PC. If it boots, your all set and close up the case. If not, close everything up and contact the board maker to get the proper BIOS Reset procedure for that particular model. This procedure usually works though. Sometimes there is no jumper but a couple of blank solder pads instead. use a bent paperclip to do the same reset. This also resets the BIOS itself (thus removing the password), so if you made any changes to the BIOS, you'll have to enter the setup program and make the changes you priviously made.
Posted on Nov 30, 2008
    Scholar:
  • 57 Answers
There is a version of Knoppix (Linux) that can fix your problem. It requires you to burn a bootable CD, so you may have to have someone else do that for you. Here's their web page:
http://www.knoppix-std.org/index.html
(Click on the FAQ to read about it)
1) Burn the cd image (knoppix-std-XX.iso) to a CD.
2) Make sure that your machine can boot to CD. (hint: check the BIOS settings)
3) Reboot the machine with the CD in the CD-ROM drive.
4) Welcome to Knoppix-STD. Play nice.
Once you boot your computer with this CD, you need to run some commands (and it gets rather technical here).
Please read the readme file at:
http://home.eunet.no/pnordahl/ntpasswd/README.txt
(I know, it's a foreign address, but it is only a text document and I've checked it for "problems".)
He explains how to use "chntpw". This utility is very handy and I've used it on a Windows 2000 and a Windows XP machine.
There is another bootable CD with a different program to use. Look at: http://home.eunet.no/~pnordahl/ntpasswd/
I can't guarentee this one works at all or doesn't have any malicious code in it.
Posted on Nov 29, 2008
  • pklinuxguru
    pklinuxguru Dec 30, 2008
    On re-reading the question, it appears it might be the BIOS password that was set, which Mullyharley has a very good suggestion to fix.
    If not, then ninja502 has a good solution that should work. You might not even need a password for the Administrator because a lot of times no one puts in a password for the administrator (yes, that's bad, but if it's your case, that's good.)
  • 395 Answers
To log on to a computer as the administrator to reset a password, when that computer is in a workgroup of more than one member, follow these steps:
  1. Log on as an administrator.
    1. Restart the computer, and then press the F8 key during startup until the Windows Advanced Options menu appears.
    2. On the Windows Advanced Options menu, use the arrow keys to select Safe Mode, and then press ENTER.
    3. Select Microsoft Windows XP edition, and then press ENTER.
      Note In this step, edition represents the correct Windows edition.
    4. On the To begin, click your user name screen, click Administrator, and then type the administrator password.
    5. Press ENTER, and then click Yes.
  2. Reset the password.
    1. Click Start and then click Run.
    2. Type control userpasswords2, and then click OK.
    3. Click the name of the user account that you want to reset the password for.
    4. Click Change the Password, and then type a new password.
      Note If you do not want to use a password, click Remove password, and then continue to step "e."
    5. Click Change Password.
    6. Restart the computer, and then try to log on to Windows XP again
How do I change country settings?
Amazon has by far the best help section of any tablet manufacturer on the planet. See number 5.
  1. Turn on the device. Press and hold the power button at the top of the device for two seconds, or until the screen turns on.
  2. Select your device language, and then tap Continue.
  3. Connect to a Wi-Fi network, if possible. If you're not able to connect to a Wi-Fi network, tap Complete Setup Later. However, you will not be able to set up your child's profile or add content to their profile until you are connected to Wi-Fi.
  4. Register your Fire HD Kids Edition tablet to your Amazon account. If you don't have an Amazon account, you can create one now. Note: The Amazon account you use to set up the Kids Edition tablet is used to set daily time limits or purchase additional books, videos, and apps to add to your child's library. You should use the Amazon account that you use to purchase physical or digital products on Amazon. You do not need to create an Amazon account for your child.
  5. Select your time zone. The time zone is how you set the time and date for your Fire tablet.
  6. Select either Setup your child's account to create a profile now, or Setup later to create a profile at a later time.
  7. Add a child profile. Select an image for your child's profile, and then enter your child's name, gender, and birthday. Then tap Continue.
  8. Share content with your child. If you have purchased digital content, tap the check box next to each title you want to add to your child's profile, and then tap Continue. Tip: Tap For Kids to view recommended family-friendly titles in your library, or tap a content library (for example, Books) to view and select individual titles on your own.
  9. Set a lock screen password or PIN. To prevent your child from accessing device settings, web browsing, social media, in-app purchases, and more, you must set up a lock screen password for your profile.
  10. Launch FreeTime. After your child's profile has been created and has content added to it, you can launch your child's profile and they can start using it to make progress towards their educational goals. Alternatively, tap Set Daily Goals & Time Limits to choose different educational goals or time limits for when or for how long your child can use their Fire HD Kids Edition tablet. Tip: If more than one child will share the Kids Edition Tablet, you can create a lock screen PIN for each of their profiles so that each child only accesses content that is appropriate for them.
Set Up Your Fire HD Kids Edition Tablet
Mar 18, 2016 | Amazon Fire HD Kids Edition - 7" - 8GB
How do I unlock the HDD Password ?
Short answer: without the password, you cannot wipe it.
May 19, 2014 | Samsung 23" Touch-screen Series 7...
Forgotten parental password
Setup xo tablet but I dont remember doing a parent password n now its asking for one an I don't no it. Trying to get password to set wifi
Dec 10, 2013 | XO Vision Tablets & eReaders
I put family settings on my xbox 360 to stop my child playiny adult games, now i cant remember the code to take it off again
You have to contact MS support. They will provide you a code that will allow you to reset the parental controls.
Apr 21, 2011 | Microsoft Xbox 360 Console
Son left home for a job left his PC behind was going to give to younger child has system password (that Older son forgot)
If he set a password in the BIOS, this can easily be solved by unplugging the computer from the wall, opening it up, and removing the CMOS battery (a flat, lithium "button cell" battery on the main system board inside), for 30 seconds before putting it back.
If this is a Windows password we're talking about, it may be tricky getting inside. Since you're giving it to someone else, why not locate the Windows Recovery Disks, and boot the computer up with them in the driver, re-install windows? Might be safer in the long run, as it will erase everything, and give the child a computer with a clean slate. Unfortunatly, if this is done- then everything your son saved on the computer will be erased clean, and be unrecoverable.
Dec 26, 2010 | Intel Computers & Internet
Paid a years on xbox360 gold membership for my son, xbox is connected to live. I am connected for first month free but my son can not get connected.
Your son's xbox live account might have no permission to access online xbox gaming, to be able to check and correct this problem try following this steps:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Xbox LIVE Controls.
  3. Sign in using the e-mail address and password you used when you set up your child's Xbox LIVE account.
  4. Select Online Gameplay, Xbox 360 Online Games.
  5. Select Allowed or Blocked
Jun 10, 2010 | EA Sports Video Game Consoles & Games
My child put a passcode on my hp how do i take it off
is it windows password or system setup password....if it is system password go to http://www.cgsecurity.org/wiki/CmosPwd
Mar 11, 2010 | HP Pavilion dv9000t Notebook
Password on famliy setting for xbox live preowed console
From the XBox website:
Managing Xbox LIVE Activity
Xbox LIVE Controls come into play only when you take Xbox 360 online, and they're linked to a child's profile and gamertag. When an Xbox LIVE account is created, the service asks for the member’s age to determine whether to apply Family Settings to that account.
Parents are also required to create or use an existing Windows Live ID. The Windows Live ID is associated with the child’s Xbox LIVE account and protects the settings from being changed later by the child. To change a child’s settings, first select the child’s account name and connect to Xbox LIVE. Once signed in, enter your Windows Live ID password to unlock the settings.
To see these controls, go to My Xbox, open System Settings, then selectFamily Settings, Xbox LIVE Controls.
Aug 25, 2009 | Microsoft Xbox 360 Console
Add password
when the computer is starting up, you can enter the BIOS setup by pressing either:
esc, delete, F2 or F10.
or try to look good when it start up witch is the right one for your system.
In the setup, there is a security setup, and the first one down is the boot up password.
set it and remember F10 to accept the change.
/Teis
Was this solution helpful? Show your Appreciation by rating it:
Nov 30, 2008 | Computers & Internet
How to take off child proof lock?
try 0000???
Parental Menu Options
1. Press the MENU and VOL+/VOL- button
2. Press CH+/CH- button to select PASSWORD .
3. Then input the password 0000. It will bring parental menu display on the
screen.
The "Default Password" preset by the manufacturer is
"0000" . If you want to change the preset password to your own password, just
choose any four digits that can be easily remembered and set. Once you set
password for a particular channel, that channel will be blocked.
to reset tv you might have to contact support at this link.
http://www.haier.com/servicesupport/index.asp
Apr 12, 2008 | Haier HLH15BB 15 in. LCD Television
Computers & Internet Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
