Question about Kenmore 632 sq. in. 16324
Grease Drip Pan and Tray
I need a replacement drip pan and tray for my Kenmore 16324. Cannot find the model at Sears service website or anywhere else. Mine rusted through and broke.
  • spaint Feb 16, 2009
    My grease pan rusted through also and I also cannot find the replacement part
I had the same problem. I called Sears Parts direct and they sent me the part number. You can find it online here:
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=P02717137B&productGroupId=0071&supplierId=141&pathTaken=partSearch&filterPart=&pop=flush
Posted on Apr 14, 2009
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Water dripping into the fridge, was told their might be a clogged drip tray but don't know where it is.
the drip pan is under the unit,, along the edges of some models inside, are little alleys that lead to the drip pan, sometimes they fill with ice and need to be cleaned out , look along the inside walls of the freezer
Jul 19, 2011 | Kenmore Refrigerators
How to remove and clean grease pan on Vermont Castings model 608SB
The drip tray is accessible from the rear of the Grill. It is necessary to lift up the pan slightly while pulling it out. Or depending on how old your VC grill is, it may be located on the left end of the grill (you should see a small handle). In which case you pull it out and was you reach the end of the drip tray, lift it up slightly to remove it.
TIP: To make clean up of the drip tray easier. Spread a thin layer of Speedy Dry (It's what NASCAR & garages use to soak up oil) on the bottom of the drip pan or tray. You can purchase a bag of it, at any auto parts store, When it comes time to clean the drip tray or pan. Just remove the tray or pan and dump the used Speedy Dry in the garbage. Then, spread a thin layer in it again. Actually, because the Speedy Dry absorbs so well, you'll find that you'll only have to dump the tray or pan occasionally.
Hope this helped you and Happy Grilling!!
Jun 23, 2011 | Grilling
HOW DO i GET TO THE DRIP PAN ON MY KENMORE REFRIGERATOR MODEL 106.57024601
Hi!
you can get to the drip pan removing the base grill in front of the unit. There is no need to empty the tray, since the water that drips into it is consumed by the evaporator. Some drip pans are even fastened by screws and can't be readily removed.
Good Luck!! Don't forget to rate this post!!
Oct 02, 2010 | Kenmore Refrigerators
I need a new drip pan. It rusted through and has broke.
Hi; call sears parts dept. for assistence in ordering a new drip pan...alpharome416
Feb 23, 2010 | Kenmore 632 sq. in. 16324
Missing grease drip pan
Call 1-800-233-9054, ask for CONSUMER SERVICE. Tell them your model number, see if they can get the trays for you.
Feb 06, 2010 | George Foreman GR30 Indoor Grill
Does anyone know a simple way of replacing the drip tray? When I removed the back the drip pan was half under the fan assembly and then wrapped around behind the compressor with some of the coil line
I agree. I have been repairing appliances for 25 years and heve never replaced the style you have. I would be a pretty difficult job. Because of its function, if the caulk is holding you should be ok. I just looked up your drain pan, the Part # is 12477402. It looks like the refrigerator would need to be tipped up and the frame for the compressor and condencor would need to be taken down.
I hope I have helped a little.
Vic
May 08, 2009 | Refrigerators
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Kenmore 632 sq. in. 16324 Logo
2,349 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
